After having nearly three weeks off through illness I am now feeling well enough to do a bit more.
First off I sprayed the anti fouling on the hull as once I start building off the deck it is going to be awkward to turn the boat upside down.
I then fixed the rear bulwarks and the port and starboard rear bulwarks.
The next thing I fixed was the vents on both port and starboard side.
The instructions aren't too bad but you do have to keep searching different pages to get all the details for the same item.
In the instruction book you have the main instructions, an exploded picture of the operation, a sheet showing where the plastic parts are, a section giving all the part numbers and where they are, a section showing what each white metal fitting looks like and two not to scale drawings. You invariably have to refer to all of these for each thing you make. I'm sure the Al Khubar and the Sentinel instructions were simpler to understand.
Anyway back to building now.
