Pages: 1 [2] 3 4   Go Down
Author Topic: Model Slipway's Maggie M Build  (Read 31923 times)
Re: Model Slipway's Maggie M Build
« Reply #25 on: January 15, 2010, 02:48:23 pm »
I second that.  Great build.     :-))  Can you autograph my copy please.
Ken
« Reply #26 on: January 15, 2010, 05:51:23 pm »
Thanks for the comments chaps and Ken methinks you are taking the xxss  >>:-( {-)
Anyway, back to the build.
Today I made and fixed the fish pools and the rear hatch.
Getting the brass wire the right shape and size for the tops was a bit of a workup and I could have done with a bit more information, ie. measurements and which bit of plastic fits inside or on the ends of the other bits.
barryfoote
« Reply #27 on: January 15, 2010, 06:09:22 pm »
Richard,
I ,love it. A great subject, beautifully built so far. Have you thought about writing a book with all your builds in? You could use all your posts on Mayhem, so not too much writing involved. It would be a superb reference book for kit builders..
Barry
Richard,
I meant every word and I am sure Ken did too......Go for it amigo.. :-)) :-)) :-)) :-)) :-))
AlanP
« Reply #28 on: January 15, 2010, 07:41:32 pm »
Great Richard  :-)) the drawings are starting to make sense to me now and I will be doing those bits in the next couple of days. Did a little today, cut some bits out including those 40 little triangular pieces, spent more time looking for them on the workshop floor than fitting them   :}
Can I ask what you used to glue the brass wire with.
Alan
« Reply #29 on: January 15, 2010, 08:19:04 pm »
Good old  "Zap A Gap Cyano" Alan.
I soldered the joint in the wire first.
« Last Edit: January 15, 2010, 08:23:53 pm by DickyD »
DavieTait
« Reply #30 on: January 27, 2010, 10:05:37 pm »
I've managed to get some photos of the hydraulics that operate the fish hopper hatch ( on the starboard side forrard where the net is emptied into the shelterdeck )
Davie Tait,
Scotland
VIVALDI
« Reply #31 on: January 28, 2010, 07:14:21 am »
Hello,
Good job!  :-))
I discovered a little with this kit, the manufacturer model slipway, and I must say that the contents of the box is very attractive, and the work done behind is very good.
If you continue like this, you will eventually convert meto the kit!  :D
KÚnavo, Philippe!
« Reply #32 on: January 28, 2010, 08:53:34 am »
Hello,
Good job!  :-))
KÚnavo, Philippe!
Think your standard of build is way above doing kits. Thanks for your comments.
VIVALDI
« Reply #33 on: January 28, 2010, 09:11:41 am »
Thank you DickyD!  If I did, it would be just for fun...
And maybe I will not gifted kits ... I've never done  :embarrassed:
KÚnavo, Philippe!
« Reply #34 on: February 04, 2010, 01:25:00 pm »
After having nearly three weeks off through illness I am now feeling well enough to do a bit more.
First off I sprayed the anti fouling on the hull as once I start building off the deck it is going to be awkward to turn the boat upside down.
I then fixed the rear bulwarks and the port and starboard rear bulwarks.
The next thing I fixed was the vents on both port and starboard side.
The instructions aren't too bad but you do have to keep searching different pages to get all the details for the same item.
In the instruction book you have the main instructions, an exploded picture of the operation, a sheet showing where the plastic parts are, a section giving all the part numbers and where they are, a section showing what each white metal fitting looks like and two not to scale drawings. You invariably have to refer to all of these for each thing you make. I'm sure the Al Khubar and the Sentinel instructions were simpler to understand. {:-{
Anyway back to building now.
« Reply #35 on: February 04, 2010, 02:34:46 pm »
Nice work Richard
Good to see you back in
business. :-))
How do you manage to spray paint
in this temperature? 8)
Do you have a nice warm spraybooth?
Yours Aye
« Reply #36 on: February 04, 2010, 03:09:17 pm »
Hi Ned. Large window, two fans and a heated work room. Spray and get out, easy really. Don't do too much though. :-))
« Reply #37 on: February 04, 2010, 06:42:52 pm »
This afternoon I made the stack complete with mast.
Two hands are not enough for soldering. ok2
AlanP
« Reply #38 on: February 04, 2010, 07:49:44 pm »
Sorry to hear you haven't been well Richard, hope you are fully recovered now.
I know what you mean about the instructions, did think about taking the book to bits, but now I put clips on all the relevent pages.
Cheated while waiting for your posts  :-) and painted the whole hull apart from the water line and the yellow line, Ill have to be careful that I don't damage the paintwork now.
Plenty for me to go at now  :-))
Alan
« Reply #39 on: February 05, 2010, 05:30:58 pm »
Today I started on the deck house, although the instructions number all the parts they are very confusing when you have to keep turning pages in the book to try and figure what goes where. I hope that the instructions are made clearer when this kit is revamped.
Tomorrow I start on the deck house furniture.
« Reply #40 on: February 05, 2010, 07:30:19 pm »
Looking good Dicky, wish I could work as fast as you appear to.
All the best
Doug
« Reply #41 on: February 05, 2010, 07:34:11 pm »
Thanks Doug, nothing else to do.
« Reply #42 on: February 06, 2010, 05:42:58 pm »
Today I have been making the wheel house furniture.
This is quite time consuming. Its a pity the Plastic Weld mixes with the ink on the plastic, always looks dirty.
I still have some more to make and I appear to have some white metal fittings missing according to the drawing, so will have to ring MSW on Monday.
« Reply #43 on: February 06, 2010, 07:02:05 pm »
Dicky,
Having cut the pieces out, I clean off the ink with surgical spirit. Looks better and stops the ink marks from showing up after painting.
Just my way.
Doug
« Reply #44 on: February 07, 2010, 04:28:59 pm »
Now that's something we don't think about. Seems a sad thing to happen.
Two choices. Paint and stickers, or replace the parts and try again.
Let us know what you do please.  Chin up.   :-))
« Reply #45 on: February 12, 2010, 05:36:33 pm »
Right I've done a bit more.
I've painted the green on the hull.
Painted and fixed the wheel house furniture.
Fixed the wheel house glazing and painted the inside of the wheel house.
Made and fixed the trawl winch base, tool boxes, gas locker and the port ventilator.
Made and fitted centre front hatch.
Made the wheel house roof.
« Reply #46 on: February 12, 2010, 07:44:48 pm »
Wow, that is nice. You must have some patience.
Well done, Dicky.
« Reply #47 on: February 12, 2010, 08:56:07 pm »
Not so much patience, more like plenty of time Ken.
Peter Fitness
« Reply #48 on: February 12, 2010, 09:35:38 pm »
But it's time very well used, Richard  O0 It's looking marvellous  :-))
Peter.
« Reply #49 on: February 17, 2010, 07:55:17 pm »
Thanks Peter.
This week I have been making up hatches and bits and pieces.
I have also started on the mast which is a bit of a work up but I think I have broken the back of it now.
It will be good when Laurie gets all the drawings and instructions revamped.
Pages: 1 [2] 3 4   Go Up
