One of the future projects Im considering is the Slipway Trent (I like the larger scale!). However, Im a little concerned over the construction of the stern railings. My current build, the Drumbeat model is 1\24th and the railings are basically brass rod of an easily bendable diameter. By comparison, the stern rails on the Trent look much thicker.
This being the case, I'd assume the brass rod(?) is a thicker diameter than used on Drumbeat which would make it not so easy to bend and make up the whole stern rails. Im not a fan of cutting each individual rail then soldering each one to the stanchions either!
Anyone built an MS Trent and care to give a few comments on how to make up the stern rails, how easy were they to do etc, etc?
