Back to the boat with renewed vigour.
As I'd had problems obtaining the rubber bumper bar to go around the boat, I decided to make my own. To this end I have used a plastic water tube which was 18mm diameter.
The first picture shows the bisecting operation on the trusty band saw. The edges were cleaned off and the heat gun applied to a test piece to check the viability of setting a bend, longways. This proved OK as shown in the picture.
It was then on to fitting the cut length to the boat. I drilled some holes into the plastic and screwed the tube to the sides. As I progressed up the length, I applied the heat gun to shape it to match the curves encountered. I then undid the screws and applied superglue to the edges and re-screwed the shape onto the sides.
I shall be removing the screws and filling the little holes to make a smooth finish later.
I then made some cabinets for the upper deck and these are shown in the picture. The little man seems to be getting smaller.
I do have to make a slatted floor for him to stand on, but he still need to be bigger.
Ken
