Had a go on the flying bridge windows today. This is my third attempt as I seemed to be having trouble with the glazing !!!
The first set ended up with superglue on the plastic windows and ruined it. The second attempt ended up with 'Bloom' on the glass, so was torn out and I went to bed.
As you can see from the pictures, I have made a more secure fixing for the frames and will be sliding the 'glass' down slots. It's all been sprayed three times so I hope this is the end of two days work.
Regarding my upgrade of the battery system, I have ripped out the old battery compartment and build a bigger, wider version. I plan to run 4 off, Six Volt types at 7 amp/hour each, in series and parallel to give me 12 volts at 14 amp/hours. I calculate this should provide top speed running for half an hour.
There is also the extra six volt battery for the bow thruster and lights.
I have fitted a 15 watt amplifier in readiness for some sound. Probably the engines or perhaps some disco music with the odd police siren noise.
ken
