Author Topic: What Glue for pool noodles  (Read 9596 times)
« on: February 02, 2010, 12:39:21 pm »
Has anybody found a glue that works on pool noodles?
Contact Adhesive may do it, but ideally I want something that won't go soft and fall apart in temperatures of 40*c and above.
Re: What Glue for pool noodles
« Reply #1 on: February 02, 2010, 04:01:40 pm »
Soy or oyster sauce!
 That what I like with noddles.  :-)
 For those that have something to add, pool noodles are swimming flotation aids made from 'hard' Extruded Polyethylene foam...
   http://lzcxpacking.en.alibaba.com/product/273764191-200595654/Extruded_Polyethylene_Foam_Pool_Noodle.html
dodgy geezer
« Reply #2 on: February 02, 2010, 04:42:38 pm »
You know that I'm playing around with an RIB for one of the next EeZeBilts - I am using 1 1/4" foam insulation for piping, which I guess is close to your noodles?
I will probably use contact to stick the insulation to the (painted) surface, but to stick foam to foam I am using pound-shop cyano - here is a picture of a joined bit of foam and one which has been pulled apart to insert a copper wire shaper...
Page created in 0.104 seconds with 21 queries.
