Author Topic: What speed controller  (Read 10104 times)
SNOOPDOG32
« on: February 10, 2010, 04:44:43 pm »
Can someone give me advise on the choice of speed controller for a Graupner 426 motor
and will proberbly use 2 6v 4amp sla batteries for a springer tug %)
Re: What speed controller
« Reply #1 on: February 10, 2010, 05:21:28 pm »
Have you any more information about the 'Graupner 426 motor'?
SNOOPDOG32
« Reply #2 on: February 10, 2010, 05:44:23 pm »
Hi Martin
not really its only got Graupner 426  and  nr-1761    9volt on it tried google but no luck
its in a springer hull i bought
SNOOPDOG32
« Reply #3 on: February 10, 2010, 05:56:01 pm »
Got a pic
FullLeatherJacket
« Reply #4 on: February 10, 2010, 06:14:39 pm »
I've just been right through the current Graupner Dealer Catalogue and this motor isn't listed any more. Part #1761 is actually now the Schottel Drive.
I think this is an old electric flight motor, although I have no idea how much current it might draw. You will need to measure the current under load at full speed with the model in the water. Once we know that figure then it will be straightforward to suggest a suitable speed controller.
BTW I would hesitate to run it on 12 volts - if it is  an electric-flight motor then it will be very fast, even using the rated maximum 9 volts.
On the whole you'd probably be as well off taking the motor out and fitting a "known" type - there's hundreds of Springers out there and these guys aren't too keen on spending a lot of money on motors and speed controllers!
FLJ
SNOOPDOG32
« Reply #5 on: February 10, 2010, 07:38:33 pm »
what set up do you recomend :-)
FullLeatherJacket
« Reply #6 on: February 10, 2010, 07:42:24 pm »
I shall leave the floor to the Forum Springer skippers to make suggestions for this. Maybe Martin or one of the Death-Eaters moderators would move this thread to that board?
FLJ
SNOOPDOG32
« Reply #7 on: February 10, 2010, 07:51:31 pm »
OK thanks for your time  :-)
« Reply #8 on: February 10, 2010, 08:17:15 pm »
Death-Eaters    -   Blinking cheek! ...... what does that mean any way?  :((
SNOOPDOG32
« Reply #9 on: February 10, 2010, 08:34:55 pm »
sure it must have been a misprint %%
chingdevil
« Reply #10 on: February 10, 2010, 08:48:26 pm »
I fear FLJ has been watching too much Harry Potter.
My springers have 550 motors in them with usualy a Mtronics esc, two 6v 4ah sla's in parallel to keep the power to 6v with the advantage of more endurance. My choice of esc is down to the fact they are fairly waterproof, and in a springer that is a good thing.
Brian
« Reply #11 on: February 10, 2010, 08:57:07 pm »
.... and Chingdevils Springer is faster than most and runs longer!  >:-o
SNOOPDOG32
« Reply #12 on: February 10, 2010, 09:01:48 pm »
Thanks all what amp esc andwhat make motor do you use
hollowhornbear
« Reply #13 on: February 10, 2010, 09:30:07 pm »
mine has a viper 15 amp, 2  6V 4 amp hour sla batteries and a speed 600 motor.
SNOOPDOG32
« Reply #14 on: February 11, 2010, 06:38:37 pm »
Thanks for all the advise think i better go shopping  :-))
craftysod
« Reply #15 on: February 11, 2010, 10:24:14 pm »
Stick a cheap chinese 100 amp esc from fleabay in it.
they work fine  %)
If it catches fire,just make another,so simple to build
SNOOPDOG32
« Reply #16 on: February 16, 2010, 10:14:19 pm »
WOULD THIS MOTOR NEED WATERCOOLING ? :-)
hollowhornbear
« Reply #17 on: February 17, 2010, 10:11:38 am »
i haven't fitted water cooling but would be a good idea as it does get warm, i'm swapping it out for a 540 soon. run times with this set up are in the region of 2 hours or more not timed it, but certainly lasts a morning session on the lake.
hope this helps you.
Arrow5
« Reply #18 on: February 17, 2010, 10:19:22 am »
Yep, go ahead and water-cool it, easy to do and should cost little.  Plus it looks scale to see the stream coming out the side.   Hollowhorn; is your motor geared or direct ?
..well can you land on this?
hollowhornbear
« Reply #19 on: February 17, 2010, 11:33:54 am »
direct
SNOOPDOG32
« Reply #20 on: February 17, 2010, 05:42:23 pm »
Thanks lads will give it a go :-))  :-)
portside II
  • tugs at rest
« Reply #21 on: February 17, 2010, 09:37:17 pm »
These lads know how to power a springer , me i stick whatever 540 size motor i have to hand and a couple of 6v sla's for power and ballast with a 15a esc Mtronics (thats what i had handy) , and for more fun switch over the wiring from 6v to 12v  :o.
As for water cooling thats easy just ship it over the freeboard's  :embarrassed: .
daz
