do you know anyone with a lath who can spin it up and fatten the tips to fit a commercial Kort.its only 2mm off the tips so very little loss off drivePeter
Thats a good idea! I would need to take off 4mm to fit a 68mm pipe! I never thought about spinning maybe even in a drill! at least then it will look more like a kotrz prop instead of the usual round normal prop!
I wouldnt spin a prop in a drill and try to remove some material off the tips of the blades.. if i were you!... blades have a habit of coming off the 'boss' at speed when you are trying to machine them... Unless you can hold them in a lathe and GENTLY (0.02" per cut) remove material, you would be better off making the kort to fit the prop...My 'how to' make a kort on RC Groups..http://www.rcgroups.com/forums/showthread.php?t=1025555
...Hi Guys...I use the Medium size Bean Tins, Then you have the correct length as well...Just build the outside up with P38...
I think Norry meant to use the tin as the base and build up the shape with P38.
