Author Topic: HMS Clyde  (Read 10499 times)
justboatonic
HMS Clyde
« on: February 18, 2010, 10:45:25 pm »
With the argies aggitating over the Falkland Islands again, it made me go all jingolistic and think of HMS Clyde. Sirmar has a model of this vessel at 1\48th(?) scale.
This makes the model a good size of around 65 inches.
Anyone built Clyde? Pics, comments, how difficult to build etc? Might get one if it kicks off again.
gingyer
Re: HMS Clyde
« Reply #1 on: February 21, 2010, 06:41:35 pm »
I have a kit sitting to get started fully
and I would Recomend it to anyone the fittings and hull are well worth it :-))
I did start cutting out the hull openings and fitting the running gear
the running set from Sitek is a must also here is a picture of one of the props agains my mouse
and it is a normal mouse :-))
gingyer
Re: HMS Clyde
« Reply #2 on: February 21, 2010, 06:46:38 pm »
Here are some of the new fittings that were required to go with this model
ships boats and the radar
close up of the radar
boat cranes
I have seen and built plenty of Sirmar kits and I have to say I think this is the best yet
I have not started this fully as I want to clear my bench of everything first
then I am looking forward to this build as it will be challenging :-))
justboatonic
Re: HMS Clyde
« Reply #3 on: February 21, 2010, 07:38:48 pm »
Awesome! What a great looking prop too!
I know the (almost) sister ships are available elsewhere in smaller scale but this looks one imposing model at this size.
Thanks for the pm too.
gingyer
Re: HMS Clyde
« Reply #4 on: February 21, 2010, 07:42:16 pm »
they are very imposing models
DARLEK1
Re: HMS Clyde
« Reply #5 on: February 21, 2010, 07:46:01 pm »
Cheers guys, it was well thought out this Clyde and all the masters were made by a pro pattern maker who works for a museum, he is also doing some other stuff for me. My mate Baz has got one and his is only in the beginning stages of the build, but, looking good so far. She is one BIG beasty, I reckon you could run it from a car battery and make it sail almost indefinately with the right motors etc.
 Plus, you can get some pretty decent 1/48th Helo kits too, we have got two Chinooks and two Seakings so far, OH and an Apache Long bow!
 Paul... :-) :-))
justboatonic
Re: HMS Clyde
« Reply #6 on: February 23, 2010, 11:05:00 pm »
Anyone know why Clyde has her name on her bow in black rather than on her aft quarter in red?
See picture.
Re: HMS Clyde
« Reply #7 on: February 24, 2010, 02:07:55 pm »
Is it because she is chartered to the MOD by VT or maybe because she is a Fishery Protection vessel?
Re: HMS Clyde
« Reply #8 on: February 24, 2010, 04:49:55 pm »
We'll clean up your build later gingyer, but what are the reports from the Navy about HMS Clyde, is she any good?
gingyer
Re: HMS Clyde
« Reply #9 on: February 24, 2010, 05:13:13 pm »
No need for clean up
I was answering the question with some pictures of the hull and some of the fittings when I actually start the build will post a new
thread :-))
gingyer
Re: HMS Clyde
« Reply #10 on: February 24, 2010, 05:29:47 pm »
I think it was only for see trials this was done
when it came to the clyde for a visit prior to going to the Falkland the bow had know name on it
but if you look at the picture of the stern you can see the standard name on the rear of the hull in red
and on the stern the pennant number but it looks as if it has been a poor attempt to cover the builders markings
below in black
Re: HMS Clyde
« Reply #11 on: February 24, 2010, 05:54:05 pm »
Yes, Paul Freshney confirms that she was flying the Red Ensign while on builder's trials when the name was painted on the bow.
gingyer
Re: HMS Clyde
« Reply #12 on: February 24, 2010, 06:05:28 pm »
that is differant from the normal RN ships then due to them being privately owned
when the Type 45's are launched they go down the slip with the White ensign flying (PR and all that guff)
but when they are towed out of the dry dock when the last of the running gear has ben fitted
then they are flying the RFA ensign and continue to do so until they have been commisioned
it used to be the Red ensign but this was changed some time back
but even then they did not have any normal mechant markings such as names of the ship on the bow
gingyer
Re: HMS Clyde
« Reply #13 on: February 24, 2010, 06:16:16 pm »
to go back and answer martin question  :embarrassed:
I believe so the 3 normal River class Mersey, Tyne and Severn have had good reports
the Clyde has used the same hull as the others but some of the fittings such as the doors and other similar
equipment was re-designed for the Clyde to with stand the south atlantic weather
the front of the superstructure also differs slightly and then the fully equipment outfit has been altered  a good bit
the Clyde is listed as being longer by about 2mts this is because of the overhang on the fligtdeck
but the basic hull is the same
brianc
Re: HMS Clyde
« Reply #14 on: February 24, 2010, 08:24:42 pm »
Hms Clyde is a pretty good ship Martin.The charter requirements was for her to be available 320 days of the year,so far they have acheived 97.5% of that,not too bad compared to the the Castle class they replaced.
justboatonic
Re: HMS Clyde
« Reply #15 on: February 27, 2010, 03:49:10 pm »
Just realised, those ships boats are 6 inches long. Hmmmmmmmm.
gingyer
Re: HMS Clyde
« Reply #16 on: February 28, 2010, 08:09:58 pm »
yes they are bigger than most ships boats :}
