Pages: 1 2 3 [4] 5   Go Down
Author Topic: 1/12 Tamar build  (Read 44809 times)
6705russell
Re: 1/12 Tamar build
« Reply #75 on: January 21, 2012, 10:01:01 pm »
Lost me Mick?  First time I have posted in over twelve months or have I missed something?
Russ
Rottweiler
« Reply #76 on: January 21, 2012, 10:12:47 pm »
Russ, I posted the request on your Severn build (is that what they call a blog? I really am not au fait with all these new fangled things!) I saw you were getting on with the Severn,and thought you might have gone off the tamar? I asked if you wanted to sell it (tamar) as both me and a pal would be interested.if the price was right of course?
Mick
6705russell
« Reply #77 on: January 21, 2012, 10:16:37 pm »
Sorry Mick, missed that one, no plans to sell her yet.....
Rottweiler
« Reply #78 on: January 21, 2012, 10:24:45 pm »
Just remembered my request was on your anyone know about Queensland request.
Building TWO boats at the same time Eh? you will be catching up with nhp at this rate! lol.
returnee
« Reply #79 on: January 22, 2012, 01:19:52 pm »
Just been looking through your build, its looking great , a credit to you.I hope my severn looks as good.
what did you fill the cut ends of the fendering with, will have to do the same with mine.
Gerard
6705russell
« Reply #80 on: January 22, 2012, 02:59:07 pm »
Hi Gerard
I used body filler then painted black, I must admit I don't use that method anymore though, I tend to cut a thin piece of rubber and glue it to the end and finely sand the joints now...
Russ
returnee
« Reply #81 on: January 22, 2012, 04:32:26 pm »
Thanks for that, I,ll try the sticking method when I get to it.
Gerard
6705russell
« Reply #82 on: January 25, 2012, 12:52:31 pm »
Last nights long winded job was to make the mast array, i decided to make the pivotal supports slightly different as I thought the usual method was to fragile to hold the mast, the main structure and vertical mast are brass tube with the supports being 4mm brass bar...
« Reply #83 on: January 25, 2012, 01:13:50 pm »
A very neat, tidy & strong soldering job there 6705russell ...congratulations..... :-))
Do you use a gas torch & Bakers [zinc chloride] liquid flux?.....or is that the jar with the name LB-CB...........
Very hard to read from 22,000 kms away....... :o Derek
6705russell
« Reply #84 on: January 25, 2012, 01:46:39 pm »
Thanks Derek
I use a gas torch and flux paste, a couple of pictures with the mast in situ....
« Reply #85 on: January 25, 2012, 02:13:00 pm »
OK....6705russell ....in the build by GGeorge of his tug with all of the mass of brass soldered components.....George acknowledged that he used a zinc chloride liquid type flux
It provides a far more uniform fluidity of the solder at each joint.......just a thought.......
The total sharpness of detail in your build is  :-))........Derek
6705russell
« Reply #86 on: January 26, 2012, 03:17:55 pm »
Mast stabilisers fitted along with the flying bridge steps,  work progressing on the bridge console....
Russ
CJ1
« Reply #87 on: January 26, 2012, 03:41:42 pm »
Russ,
That's looking so crisp! You're inspiring me to keep going, thanks.
Chris
6705russell
« Reply #88 on: January 26, 2012, 04:15:48 pm »
Thanks Chris, I think it's just a matter on concentrating on on area.. :-))
Russ
6705russell
« Reply #89 on: January 29, 2012, 08:10:24 pm »
Not much done this weekend apart from made the windscreen up and made a start on the Man lift A-frames, going to turn my attention to fitting more gadgets inside over the next few days, Action sound sytem and a home made smoke machine for the exhausts to start off with...
Russ
6705russell
« Reply #90 on: January 31, 2012, 08:43:02 pm »
Does anyone know where i can obtain a radar motor that is no more than 10mm in depth x 15mm in width?  I want to keep it as discreet as possible and there is not a lot of room under the radar base as you can see in the picture....
Russ
Wikinger
« Reply #91 on: January 31, 2012, 09:02:31 pm »
6705russell
« Reply #92 on: January 31, 2012, 09:07:32 pm »
Thanks Michael, just the job.... :-))
Russ
6705russell
« Reply #93 on: February 18, 2012, 08:30:45 pm »
Slow progress this week but managed to finish the stern railings to a point and made up the main rear door hinges, these are bolted through now using 12BA hexagon head bolts, for the railings I used 14BA bolts.
Russ
6705russell
« Reply #94 on: February 19, 2012, 06:33:26 pm »
Hydraulic rams fitted made up of brass rod and tube...
john44
« Reply #95 on: February 19, 2012, 08:26:49 pm »
What a beautiful boat
 Russ its a credit to you.
john
6705russell
« Reply #96 on: February 19, 2012, 08:43:12 pm »
Thanks John..  :D
I thought we might of had a couple of hours down the lake this morning, be glad when the better weather comes.
Russ
john44
« Reply #97 on: February 19, 2012, 08:48:33 pm »
Hi Russ, I had a few hours down the lake this morning,
Big Kev was there Russ, Tommy, Brian, Ray, John Bossons.
and the weather was brilliant down on the jetty.
john
tt1
« Reply #98 on: February 19, 2012, 08:57:09 pm »
Superb Russ a fantastic build. :-)) Where do get your nuts and bolts from? they really are so effective.
                          Regards, Tony.
6705russell
« Reply #99 on: February 19, 2012, 09:16:02 pm »
Hi Tony
I get the bolt from either  Maccs Model supplies or BA Bolts..
Russ
Pages: 1 2 3 [4] 5   Go Up
Page created in 0.135 seconds with 17 queries.
