Update!
I set out to make the steam valve spools and had problems. The first one came out ok, but no2 somehow came out off centre
, as did no 3, no4, no5 and no 6.
So, I left them for a while and tried again, this time with success, all 4 are ok, I think!
So, next job was to drill and tap the base of the steam chests to take the spool gland, first chest drilled ok, then first tap (m2) snapped in the hole grrrrr
there is no way that is coming out, or so I thought. Then I found out that taps can be dissolved without harm to brass using a solution of aluminium potassium sulphate (alum), now awaiting delivery of the magic powder, I will update on results later.
I then thought I would do a simple job, so made the flanges for connection to the steam chests.
Having succeeded with those, I thought I would tackle the steam control valves next, that went well, although time consuming getting them right.
