April 25, 2024, 06:00:48 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Chit-Chat
viper 15 help
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: viper 15 help (Read 1708 times)
stringer
Guest
viper 15 help
on:
February 28, 2010, 04:12:14 pm »
hi i am having real problems with my first viper esc.i can only set it up to work in one direction.reverse or forward.i dont think you can disable the reverse on this one so ive ruled that out.all the leads and points are standard as is the motor and battery.please help if you know a way around this.thanks
Full Mayhemer
Offline
Meridian Line, Mouth of the Humber
Re: viper 15 help
Reply #1 on:
February 28, 2010, 04:35:22 pm »
If it is the plug and play model there is no adjustment
Whichever way you push the throttle stick the first time
will be Ahead
The ordinary viper 15 has adjustable reverse and also disable
Hope this helps
Up Spirits Stand fast the Holy Ghost.
toesupwa
Full Mayhemer
Offline
USA'd ex Brit
Grand Junction, Colorado, USA
Re: viper 15 help
Reply #2 on:
February 28, 2010, 04:45:22 pm »
Disconnect the motor from the ESC...
Turn on the Tx with the stick 'mid' position, IE: all stop...
Turn on the RX and hold the button down until the light on it comes on (about 3 sec's i think)..
Push the throttle forward and hold for three seconds, return the stick to neutral...
Pull the stick back and hold for three seconds... then return to neutral..
That should set up the ESC...
Full Mayhemer
Offline
www.srcmbc.org.uk
Southampton UK
Re: viper 15 help
Reply #3 on:
February 28, 2010, 04:46:39 pm »
Idiot question number one, is your motor plugged into the right socket on the receiver ?
Idiot question number two, is it plugged in the right way round.
Richard
Solent Radio Controlled Model Boat Club
http://www.srcmbc.org.uk
stringer
Guest
Re: viper 15 help
Reply #4 on:
February 28, 2010, 04:47:29 pm »
thanks Ned its the ordinary viper.the problem is there is no reverse.ive found online instructions for reverse enable but it doesnt seem to respond to it.
stringer
Guest
Re: viper 15 help
Reply #5 on:
February 28, 2010, 04:49:12 pm »
yeah dickyd all plugged in correctly.
ive done the set up but no reverse
Peterm
Inactive
Full Mayhemer
Offline
Southam,Warwickshire
Re: viper 15 help
Reply #6 on:
March 01, 2010, 08:55:01 am »
I have had similar problems, but reverse and no forward. Solution : return to manufacturer with explanation. They are good, will either fix it or supply a new one, normally free of charge. Pete M. PS no connection with the company.
I`m not just old, I`m ancient
david j
Guest
Re: viper 15 help
Reply #7 on:
March 01, 2010, 10:06:07 am »
i agree with peterm . i have had this problem three times. they just send new ones, but never explain what has gone wrong, see if you can get any where david
stringer
Guest
Re: viper 15 help
Reply #8 on:
March 01, 2010, 11:49:29 am »
thanks to you both gonna do that today.thanks
regiment
Guest
Re: viper 15 help
Reply #9 on:
March 01, 2010, 01:39:19 pm »
i had trouble with a viper howes models exchange with out fuss
Print
Pages: [
1
Go Up
« previous
next »
Chit-Chat
viper 15 help
