Author Topic: Hand made mini swords  (Read 3263 times)
Aydemir
« on: March 02, 2010, 03:42:11 am »
Hello guys, there are some hand made mini swords made by jigsaw blades. Maybe you like them. Regards for all. Aydemir {-)
Aydemir
Re: Hand made mini swords
« Reply #1 on: March 02, 2010, 03:43:50 am »
some more pic...
Dueller
« Reply #2 on: March 02, 2010, 08:50:59 am »
Very nice. I'm always amazed at the ideas people have for making things from unexpected materials.
« Reply #3 on: March 02, 2010, 09:01:47 am »
Excellent workmanship!
 Are they made just using files etc?
Aydemir
« Reply #4 on: March 03, 2010, 11:34:19 pm »
Hello Martin, I used to shape them with Dremel hand tool (New one) I have also Black&Decker hand rotary tool. I just mark over the jigsaw blade with marker. After
I used small cutting disk and I cut the desired shape. I try to not heat the steel and I
dipped in the water several time. After that I used several small grinding stone on the
rotary tool and shaped more. After basic shaping I used small diamond hand files for
smooth the surface then used several metal sand papers. Also I used some brass  and
mahogany for hand part. Lots off sanding and polishing after just put some clear varnish
for the handle. I  was try to make like real ones there are some pic I observe.Next one
maybe Japanese Katana. Regards
Aydemir
« Reply #5 on: March 13, 2010, 05:33:45 am »
Hello pals there are two more mini swords unfinished and one mini dagger. One other
broken recycle pieces. Regard for all Aydemir.
Aydemir
« Reply #6 on: March 14, 2010, 04:52:29 am »
Two mini swords finished....
The Antipodean
« Reply #7 on: March 14, 2010, 05:06:08 am »
Great work on the Katana, very realistic.
Aydemir
« Reply #8 on: March 16, 2010, 02:23:56 am »
After Polished another  two pictures.
