Hi all,
I used to go to Victoria park in East London with my grandad in the early fifties to watch the Hydro's.
As a small boy, the booring bit was watching them try to get the motors started. As they were so highly tuned, they were very temperamental. And then when actually running, the launch was also tricky. I've never seen a bungee launch, but it looks like it would make it a lot easier. They also do tethered cars.
I also remember, that they used to have a stiff vertical wire on the boat, which stuck up about twelve inches. After the timed run was over, a brave man would hold out a stick, whilst standing in the pond just outside the perimeter of the circle formed by the boat. This stick would knock down the stiff vertical wire, which turned off the fuel supply and stopped the boat.
Even more dangerous were the flash steam straight runners. These also had a vertical wire, which was knocked down by a taught line stretched across the pond.
I never saw this system fail, but the result would have been spectacular. Flash steam boat hits side of concrete pond and exploads.
