Author Topic: Photos on the Forum & Resizing  (Read 463643 times)
stringer
Re: Photos on the Forum & Resizing
« Reply #300 on: February 22, 2017, 05:25:09 pm »
Hi Martin
can you explain how I can reduce a photo from 1mb to below 300KB, I am trying to send a photo to tiger tiger
Geoff S
you will never fail as long as you try
gregk9
    • Chasewater Model Boat Club
« Reply #301 on: February 22, 2017, 08:54:23 pm »
search online for " robosizer", its a FREE download program. Once installed it will automatically adjust the size on any picture image you wish to share on ANY program or site. O0
Best wishes.
Steve. G.
Treasurer & Membership Secretary:  Chasewater Model Boat Club
http://chasewatermbc.blogspot.com/
« Reply #302 on: February 24, 2017, 05:33:28 pm »
If using windows 10, open it with Paint (the included picture handler).  Under the "home" tab is a "resize" command where you can pick the percentage size wanted.  Then use "save as" to put it somewhere that you can find it again.  Check that the new file size is as expected, attach and send.
Previously I have used the FREE image handler "irfanview".
TheLongBuild
  • Build em, and play hard..
« Reply #303 on: February 24, 2017, 06:00:58 pm »
Pixresizer
Been Using it for over 6 years no issues..
http://bluefive.pair.com/pixresizer.htm
Peter Fitness
« Reply #304 on: February 24, 2017, 09:38:10 pm »
There's also a free program called Light Image Resizer available here http://www.obviousidea.com/windows-software/light-image-resizer/ I've been using it for years.
Peter.
Mark T
« Reply #305 on: July 22, 2017, 09:38:23 am »
Test - It worked  %% %% %%
Tug Fanatic
« Reply #306 on: July 22, 2017, 10:00:07 am »
I use Irfanview (free) which not only lets you resize but also change how compressed the image is. Tis means that within the 300kb limit I can get much larger images or I can reduce the image data size to help Martin. These images are set to jpeg quality 60
The first image is 1920 x1074 (full hd) and is 287kb
The second image is 1450 x 811 and is 205kb
« Reply #307 on: September 08, 2017, 03:08:56 pm »
Hi Tug Fanatic.
  Can you please tell me where in Infraview you change the JPEG quality , I am unable to find it .
cheers.
« Reply #308 on: September 09, 2017, 09:27:25 am »
Hi Tug Fanatic.
cheers.
In Ifranview, while showing your image, click the "Image" tab, then click "resize/resample" from the drop down menu.  Then "save As" somewhere else or with a new name.  The other available image adjustment options are in the same drop down menu.
Chris G
  • Andree1v the real thing.
« Reply #309 on: December 03, 2017, 04:36:19 pm »
Dear Administrator
I have been referring to a build blog by tt1 titled Alice Upjohn my third build as I have just started a long owned kit by Metcalf Mouldings of the same lifeboat. I have found this build blog very interesting and helpful but today many of the photos on the blog have disappeared.
Is there any particular reason for this or is it a quirk on my laptop.
If Tony sees this I wish to thank him for his work and the help it has given me so far, long way to go yet.
Regards Chris G
( https://www.modelboatmayhem.co.uk/forum/index.php/topic,35283.msg374802.html#msg374802 - Admin  )
C-3PO
« Reply #310 on: December 03, 2017, 04:51:04 pm »
Chris G,
The images you refer to were on an external server to the Mayhem forum and then linked using a URL from the external source to the post on Mayhem e.g. http://s12.postimage.org/is1e1jkbt/1_Large.jpg
The images don't appear to exist any more on the external server - the only person you could ask about the reason they no longer exist at the lookup URL link is the person that put them their in the first place who was more than likely  "tt1"
C-3PO
TheLongBuild
« Reply #311 on: December 03, 2017, 09:08:22 pm »
tt1 is last showing as active on this Forum Feb 17
RAAArtyGunner
« Reply #312 on: December 04, 2017, 03:59:28 am »
Dear Administrator
Regards Chris G
Chris,
My suggestion is to personal message the author tt1, look him up in members list, and ask him if he can provide copies and or info as required.
Unfortunately you will find several threads on here with the same problem because the authors didn't and some still don't post from their computers but from the "cloud". It is out of the control of the administrator/moderators to rectify.
« Reply #313 on: December 04, 2017, 10:50:07 am »
  O0
« Reply #314 on: December 14, 2017, 08:12:11 pm »
« Reply #315 on: December 14, 2017, 08:18:33 pm »
Weh hey that seems to work onwards and upwards I think
« Reply #316 on: December 14, 2017, 08:30:00 pm »
C-3PO
« Reply #317 on: December 17, 2017, 10:16:42 am »
This post is being used to try to understand the issue with inserting images
C-3PO
« Reply #318 on: December 17, 2017, 10:18:22 am »
C-3PO
« Reply #319 on: December 17, 2017, 10:22:14 am »
Long file name test
T33cno
« Reply #320 on: December 17, 2017, 10:39:14 am »
T33cno
« Reply #321 on: December 17, 2017, 10:39:35 am »
Why did that work? is it fixed??
bfgstew
  • Comfortably Numb
« Reply #322 on: December 17, 2017, 10:51:11 am »
bfgstew
  • Comfortably Numb
« Reply #323 on: December 17, 2017, 10:51:57 am »
Previously it would time out with database error?
« Reply #324 on: December 17, 2017, 12:19:41 pm »
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23   Go Up
Page created in 0.011 seconds with 15 queries.
