Author Topic: Low-tack Masking Tape  (Read 8751 times)
BarryM
« on: March 29, 2010, 01:39:58 pm »
Can anyone suggest a genuingly low-tack masking tape that can be applied to thin card without removing the surface on removal?
Ordinary masking tape takes the surface paper off one in three times. Some supposedly low-tack stuff that I had used on walls does likewise.
Any thoughts?
Barry M
Re: Low-tack Masking Tape
« Reply #1 on: March 29, 2010, 01:45:24 pm »
Barry M....try PVC electrical insulation tape......  OK for paint masking & will be OK as long as you remove @ an approx 160 degree back angle......... O0 Derek
« Reply #2 on: March 29, 2010, 02:54:30 pm »
Have you tried Tamiya, I use it all the time.
BarryM
« Reply #3 on: March 29, 2010, 03:46:08 pm »
Dicky - Have you used it on card?
Barry M
John R Haynes
« Reply #4 on: March 29, 2010, 05:06:44 pm »
Got to be Tamyia, available from Squires or Hannants in different widths
« Reply #5 on: March 29, 2010, 05:23:34 pm »
I used a bit when I had my trains, worked OK. Can but try.
boatmadman
« Reply #6 on: March 29, 2010, 05:36:32 pm »
I stick a bit of normal tape onto my shirt, then put it on the model, that takes a lot of the tac off it - try it.
nemesis
« Reply #7 on: March 29, 2010, 06:15:32 pm »
Hi, Tamiya tape every time, very good product. Nemesis
BarryM
« Reply #8 on: March 29, 2010, 06:23:22 pm »
I've tried Dereks suggestion and it works fine as long as the tape is not left on for too long. Thank you Derek.  :-))
I note all the recommendations for Tamiya but are they the result of using it on card?
Cheers,
Barry M
DARLEK1
« Reply #9 on: March 29, 2010, 06:28:33 pm »
I have used the 18 mm Tamiya stuff to tape plans on to a wall, but bearing in mind the plan was held in place for several months with it, it did tear the top layer of paper off the plan, I have also used it short term on card and it was OK, but not knowing what type of card you are using can not say that it would be OK to use.
 Paul...
BarryM
« Reply #10 on: March 29, 2010, 06:38:32 pm »
White artists card about 1mm thick.
DARLEK1
« Reply #11 on: March 29, 2010, 06:48:48 pm »
It might be ok on that Barry, give it a try. Is that the smooth stuff artists card?
 Paul...
BarryM
« Reply #12 on: March 29, 2010, 06:51:39 pm »
Paul,
Yes,
Barry M
Timo2
« Reply #13 on: March 29, 2010, 09:11:37 pm »
Hi
   Try a old type Hardware store  ( Ironmonger )
      http://www.stukproducts.com/products.php?scat=Low%20Tack%20Masking
  Timo2
Tankerman
« Reply #14 on: March 30, 2010, 11:51:44 am »
Barry, Tamiya masking tape works perfectly on card. I have even used it on printer paper with no problems so long as you remove it once the paint has got tacky.  Chris
BarryM
« Reply #15 on: March 30, 2010, 12:10:05 pm »
Chris,
Thanks for your info which is reassuring.
I experimented with Derek's suggestion of insulating tape on some scrap and it proved to be worth following. It also rang a bell with me which led to an expedition to the bitsa box where I found some rolls of 3mm wide plastic tape given to me some years ago by a draughtsman. He was having a clear out as he had a shiny new CAD setup and suddenly paper and pencils were old fashioned. It worked for him and it seems to be working for me. If it proves OK, that's the road I'll go; if not, I'll add to Tamiya's profits.
Thank you to all who replied.
Barry M
Mankster
  • Wheelerdealer
    • RC Model Submarines
« Reply #16 on: March 30, 2010, 01:28:29 pm »
Automotive masking tape (I use Blue 3M) is a low cost alertnative when painting big areas compared to Tamiya. Works fine on card.
sinjon
  • Sinjon
  • Model Bioat Mayhem Forum is the Best!
« Reply #17 on: May 01, 2010, 08:45:43 am »
Some years ago when I worked in an art studio, for airbrushing on paper we used to run Sellotape backwards and forwards over the edge of a table, it would take the real ' stickiness ' off, and had the advantage that you could see through it.
RaaArtyGunner
« Reply #18 on: May 02, 2010, 05:11:31 am »
Struth, my wife was not impressed   <*< with my shirt afterwards. She got really tacked off.  >>:-(  {-)
