Author Topic: 2.4 ghz rc  (Read 6938 times)
davidsg1a
2.4 ghz rc
« on: March 31, 2010, 01:50:48 pm »
Hello everyone, I'm looking for a 2.4 ghz 5 channel rc system, just wondering if anyone knows where to get one at a good price and what models are good, I would be most great full for your help.
Cheers David
bosun
    • bosunsmodelboats.com
Re: 2.4 ghz rc
« Reply #1 on: March 31, 2010, 01:56:58 pm »
Hy David,
Check out Giant Cod, I have two of there TX and about 8 Rx, very cheap and very good. A lot of the guys on here have them.
Bosun
Peterm
  • Inactive
Re: 2.4 ghz rc
« Reply #2 on: March 31, 2010, 02:57:43 pm »
I think Howes models do both Planet and Giantcod.   Other alternative, do a Google Search.   Pete
I`m not just old, I`m ancient
brockya
Re: 2.4 ghz rc
« Reply #3 on: March 31, 2010, 04:06:57 pm »
Hi.
The six channel RadioLink from Giant Cod is first class, had no trouble at all and with receivers so cheap you can set up a whole fleet. The service from Giant Cod is also great, all arrived next day.
Richard.
garston1
Re: 2.4 ghz rc
« Reply #4 on: March 31, 2010, 05:25:23 pm »
yep, definitely giant cod! :-)) :-))
Dueller
Re: 2.4 ghz rc
« Reply #6 on: March 31, 2010, 07:26:13 pm »
Just in case you were wondering, the switch on the top right of the planet system is the channel 5 on/off switch. Switch it on and channel 5 soft starts up to full power and the same in reverse when you switch it off.
The reciever on the planet system does not look as robust as the giant cod, but to date i've had no problems at all.
The reciever binding procedure is just about the same for both models.
dodgy geezer
Re: 2.4 ghz rc
« Reply #7 on: March 31, 2010, 07:50:40 pm »
Trim is nicer on the Planet system - the Giant Cod has tatty trim, and if they are still like the two I have, needs a 100k resistor added to the stick pots to get the last 10% of throw to work.
But the GC kit is solid, good feel, and the 4-channel system is cheap as chips at £25. If you really have to have 5 channel, GC do a 6-channel set for £52, but I think that may be more than a Planet....
davidsg1a
Re: 2.4 ghz rc
« Reply #8 on: March 31, 2010, 08:04:32 pm »
Thanks for all your help gents, am i right in saying that on the 4 channel gc it's two four way sticks, also do you think at the show in south sheilds on the 10th april that there might be dealers there and better deal?
David
dodgy geezer
Re: 2.4 ghz rc
« Reply #9 on: March 31, 2010, 09:15:23 pm »
1 - yup, two 4 way sticks
2 - I think that Giant Cod cut prices to the bone, so there probably won't be any further discounting...
3 - I suspect that GC get these low prices by lowering quality control, so it's worth checking the kit over. If there's anything wrong GC will certainly replace or refund - they do good service, but with those low prices I would be cautious. That said, I'm really happy with the two £25 GC systems I have...
4 - Interestingly, on the PCB inside, there are several connector positions which are unconnected to any controls. GC have an electronics specialist on their forum who says that the basic electronics in the box are 6-channel, and so it may be possible just to connect a switch or a pot to these connect positions and get extra channels. The £10 GC receiver is 6-channel....
davidsg1a
Re: 2.4 ghz rc
« Reply #10 on: April 01, 2010, 10:44:34 pm »
Hey gents, thanks for the advice, iv orderd the giant cod 4  channel, hopefully give it a run this weekend and i'll let you know how it goes.
Cheers David
davidsg1a
Re: 2.4 ghz rc
« Reply #11 on: April 02, 2010, 11:09:03 am »
Does anyone know if the guy at giant cod is still in china?
David
tt1
Re: 2.4 ghz rc
« Reply #12 on: April 02, 2010, 02:18:35 pm »
Excuse me for jumping in on the thread, but can anyone please explain to a newbie the "binding" the transmitters?  {:-{
           Chers, Tony.
Re: 2.4 ghz rc
« Reply #13 on: April 02, 2010, 02:32:05 pm »
Binding is setting the receiver to only react to your transmitter
With Giant Cod power up receiver turn on transmitter
Press 'bind' button on receiver momentarily and away you go!
Yours Aye
tony23
Re: 2.4 ghz rc
« Reply #15 on: April 02, 2010, 03:54:08 pm »
I notice nobody has recommended Spektrum so I will it's first class gear and an after sales that cannot be beaten. :-))
tt1
Re: 2.4 ghz rc
« Reply #16 on: April 02, 2010, 03:57:28 pm »
Thanks, Ned.
          Tony.
tt1
Re: 2.4 ghz rc
« Reply #17 on: April 02, 2010, 03:59:44 pm »
Oops Sorry Martin, just spotted your link, thanks to you also,
       Tony.
dodgy geezer
Re: 2.4 ghz rc
« Reply #18 on: April 02, 2010, 04:41:51 pm »
"Excuse me for jumping in on the thread, but can anyone please explain to a newbie the "binding" the transmitters? ..."
With a 'normal' Transmitter/Receiver pair, you work on a 'spot' frequency, and nobody else can use that frequency while you are using it. So you usually buy several frequency crystals, and change them round to make sure that you do not clash with any other pond user.
2.4Ghz is different. Everybody transmits on the same frequency, but they send packets of information with an address attached to each, any your receiver only responds to packets with your address on. This is set up when you first buy the radio - you turn the transmitter and receiver on together, then press a button to link them. Thereafter, that receiver only responds to that transmitter (until you re-bind to a different transmitter, should you ever want to...)
So, no more worrying about frequency clashes....
Re: 2.4 ghz rc
« Reply #19 on: April 02, 2010, 04:42:36 pm »
Spektrum is great gear...... but it's 5 times the price!
tt1
Re: 2.4 ghz rc
« Reply #20 on: April 02, 2010, 08:26:45 pm »
Thanks for the info D.D. - you must have been reading my thoughts either that or you heard the old cogs turning!
    Cheers, Tony.
tt1
Re: 2.4 ghz rc
« Reply #21 on: April 02, 2010, 09:05:11 pm »
Sorry dodgy geezer last reply was for you (D.D.?) doh!
dodgy geezer
Re: 2.4 ghz rc
« Reply #22 on: April 02, 2010, 10:49:29 pm »
That's all right - I'll answer to anything....
Other points about 2.4Ghz - good at rejecting radio interference - can suffer from difficulties in getting a signal at some aerial attitudes, so the receivers often have two aerials to minimise this problem - signal won't go through water, so no good for submarines. Apart from that - treat as 27Mhz....
tt1
Re: 2.4 ghz rc
« Reply #23 on: April 03, 2010, 09:07:01 pm »
Thanks Dodgy - learning something everyday :-))  If I'm not careful I'll soon have an idea of what I'm doing!
      Cheers, Tony.
Aeronut4
Re: 2.4 ghz rc
« Reply #24 on: May 25, 2010, 02:44:28 pm »
Just something to bear in mind - as previously stated, 2.4gHz doesn't like water, so be very wary of using it in foggy, misty, damp or very rainy conditions - it will still work, but range will be greatly reduced.
Page created in 0.101 seconds with 21 queries.
