I have found that the Uniross Hybrio cells seem to do what it says on the tin - they come charged and don't self discharge to anything like the same extent as standard NiMh cells.
I do have a fast charger though, also made by Uniross, which is rated at 2,500 mAh for two cells, 1,400mAh for four. The cells themselves are 2,100 mAh and they do get pretty warm when charging. There is nothing in the charger instructions that prohibits any type of battery and the battery pack states that "works in any charger". nevertheless I wonder if it might be better to use a slower charger as the small print round the bottom of the battery quotes a 5 hour rate of 420mAh.
