Author Topic: ACTION MOTOR MIXER P40C AUTOSET  (Read 2859 times)
crzydoyle11
« on: April 12, 2010, 08:45:30 pm »
OK I am thinking of buying the Action Motor Mixer P40c auotset. My question is there any real benfit of having it install into my boat?
And for my RC controll unit I will be using a 2.4 Futaba unit will there be any problems or is any thing else I may need to install with unit?.
Please let me know thank you for any input into this unit again thank you..
Re: ACTION MOTOR MIXER P40C AUTOSET
« Reply #1 on: April 12, 2010, 09:00:34 pm »
To be honest before I fitted a mixer I always wondered why anyone would bother with them.
Then I fitted 1 and on my 3 shaft model I just wouldn't be without it.
Even on 2 shafts I can operate the throttle on my left hand stick with a ratchet and turn without touching the throttles.
So yes, in my opinion there is a benefit.
Plus it leaves another channel for functions if required.
riggers24
  • Just full of stupid questions
« Reply #2 on: April 12, 2010, 09:54:12 pm »
All of ACTion gear is tested and I know Dave has a Futaba 2.4 set just for testing purposes. Have you already got the ESC, if not I would look at the P94 twin ESC plus mixer. Nice bit of kit
http://www.action-electronics.co.uk/mixers.php
I will finish the crash tender someday - Still got tooo many toys to play with
crzydoyle11
« Reply #3 on: April 13, 2010, 03:08:22 pm »
Thank you shipmates for the reply back sounds like a good idle to get the unit. as for esc uint I already have them they come with the tug. so I am going to use them maybe later I will use Action P94 money is a little tight right know.  So I guess I nothing else to hook the unit in with than? One more thing I can use the P40 to hook in thre bow Thruster as well if i am reading this right?
FullLeatherJacket
« Reply #4 on: April 13, 2010, 04:42:37 pm »
No. The third output is for the centre motor in a three-screw installation.
FLJ
crzydoyle11
« Reply #5 on: April 14, 2010, 03:59:58 am »
thanks fullleatherjacket did not want to make that mistale.  :-))
FullLeatherJacket
« Reply #6 on: April 14, 2010, 07:50:40 am »
That's OK, but please do read the full P40C manual before you plan any further.
http://www.action-electronics.co.uk/pdfs/P40C.pdf
You may  need a separate battery for each motor but you will certainly need a separate supply for the receiver. If your ESCs have BEC then this must be disabled in BOTH units, and there are certain makes of ESC which have proven not to like working properly with any type of mixer. PM me for details to see if those you have planned to use are on the list!
If you don't already have two suitable ESCs then P94 is a better buy (apart from being a more versatile and compact unit), being cheaper than two x 20A ESCs and a mixer when bought together. You can knock approx 15% off the published UK prices for US exports too, so a P94 will cost around $110US built, tested and shipped.
FLJ
