Author Topic: Caldercraft Riverman  (Read 7947 times)
« on: April 24, 2006, 07:19:33 pm »
Help has anyone built htis kit as I am at the moment threatening to take bloomin big hammer to it!!!!Having purchased this part built  Tug s/h it was fitted with a kort nozle no motor,deck had been fitted!!!!superstucture poorely built so it was back to teh drawing board.Having fitted a MFA 6;1 motor 12v batt reciever,and servos etc it was time for the bath test,all well and good,had to ballast the stern to get the kort in the water(this is where the problems start)well it was time for proper testing so down to the lake I went,oh bloomin heck water all over the deck far too low in the water!!!!back to the drawing board,plan b change from the 12v batt to 6v change motor  remove some rear ballast try again,not enough this time kort out of water,what I anm getting at is when it is ballasted to get the kort in the water as soon as forward motion is started water seems to be very close to the deck level and generally come over.Has anyone else had this problem with this model or is it just me!!!!.If i cant cure it I will remove kort and propshaft and scrap the flippin thing help
Daryl
Re: Caldercraft Riverman
« Reply #1 on: April 24, 2006, 08:47:09 pm »
If no one steps forward an idea is to look on the SWAMBC site for the Shepton Mallet Drifters MBC. One of their members has one which works quiet well as he enters stearing competitions with it. As I have seen one at a reggatta last year.
Good luck
Daryl
riggers24
  • Just full of stupid questions
« Reply #2 on: April 24, 2006, 09:47:00 pm »
The motor/gearbox you have fitted works better on 12v, really it should be a 2.5:1 gearbox. You may find that you are putting torque on the prop so it is pulling the 'bottom' end of the boat down. Try contacting cauldercraft and find what motor they recommend. You could try a low drain motor direct drive.
Riggers
I will finish the crash tender someday - Still got tooo many toys to play with
Doc
« Reply #3 on: April 30, 2006, 12:36:36 am »
Stavros,
And just a thought.  Is the kort canted to point upwards?
 - 'Doc
blitzbob
« Reply #4 on: September 18, 2006, 09:09:49 am »
we've had ours on the water for about a year with no probs, useing a 540 moter on 6v 10 ha batt we had trouble bring it down to the water line. only trouble we had was a little water coming up the tube.
bob
« Reply #5 on: September 18, 2006, 06:46:46 pm »
These smaller models perform far better on direct drive.
A 380 is big enough for this model, but I would fit a 545 on 6 volts.
dash8man
« Reply #6 on: August 04, 2008, 04:55:29 pm »
Stavros,
    Would love to see a pic of your finished Riverman if you still have it. Cheers.
Bil.
« Reply #7 on: August 04, 2008, 05:45:50 pm »
Sorry dont have any moved it along to make room for other projects
alan colson
  • I Just Dabble In Model Boats
« Reply #8 on: August 04, 2008, 07:37:47 pm »
I run my Riverman on direct drive, with 385 motor and 7.2 volt nicad, great steering boat.
Alan
dash8man
« Reply #9 on: August 04, 2008, 07:42:19 pm »
Any pics Alan? I'm interested in building this one. Cheers.
Bill.
« Reply #10 on: August 04, 2008, 09:18:24 pm »
 O0
dash8man
« Reply #11 on: August 04, 2008, 09:29:05 pm »
Nice Martin! Thanks!
Bill.
« Reply #12 on: August 04, 2008, 11:13:34 pm »
Right then just spent over an hour trolling through 40G of photos and have found the only 2 that I have of the Riverman.She was powered in the end with a MFA 6;1 Ratio geared motor swinging a 60mm Kort nozzle with a 12v 7amp batt and she would run 4hrs+ with this set up.Yes fair comment it was overpowered but that is how I like them,my ans to everyone is do you by a Ferrari and drive it flat out all the time.Heck NO,you can never have to much power
dash8man
« Reply #13 on: August 04, 2008, 11:17:52 pm »
Stavros: your the man! Thanks. Cheers.
Bill.
« Reply #14 on: August 04, 2008, 11:34:21 pm »
My Riverman you will note is not exactly correct it!,the hull had been butchered to this side profile by the previous owner.I initially bought it off eaby just to get the Kort, but everytime I looked at it,it grew on me and I ended up having to cobble everything up.I must admit I was to tightfisted to by hte full fittings kit off caldercraft to do the job properley.If there is one model I regret selling is this one :'(
« Reply #15 on: August 05, 2008, 09:11:59 am »
Found some more.... :)
alan colson
« Reply #16 on: August 05, 2008, 03:00:35 pm »
dash8man, there is no need for me to supply any pictures of my Riverman, as Martin has posted quite a few and mine is almost identical right down to the colours.
Alan
dash8man
« Reply #17 on: August 05, 2008, 04:11:22 pm »
Thanks Martin. Great stuff!  :D
Bill.
« Reply #18 on: August 05, 2008, 08:31:12 pm »
3 more....
dash8man
« Reply #19 on: August 05, 2008, 08:49:56 pm »
Ok, I asked and I received! Thanks guys.
Bill.
Page created in 0.101 seconds with 21 queries.
