Author Topic: SEA IMP build  (Read 10806 times)
lifeboatpaul
SEA IMP build
« on: April 15, 2010, 07:49:06 am »
I thought I would share with you my build of the Sea imp ,Canadian tug.
 The hull I used to base the model on is a George Turner 14" ABS tug hull ,as I cant seem to find any plans of this little boat ,
I have resorted to scaling up pictures of the internet( most of them from from this site , taken at shows).
first things first the hull needed to be widened , the width of the Sea imp is nearly half the length , the GT tug hull is already in two halves , so the keel was cut out and a 2" strip of styrene was added to the centre and formers fitted to the bow and stern to give a frame work for the  car body filler to adhere to.
lifeboatpaul
Re: SEA IMP build
« Reply #1 on: April 15, 2010, 07:50:17 am »
Hull with 2" strip of styrene fitted
lifeboatpaul
Re: SEA IMP build
« Reply #2 on: April 15, 2010, 07:51:51 am »
Car body filler used to fill gaps and blend in the curves.
"D" section styrene strips were heated up with a modellers hot air gun( used by aero modellers to shrink solorfilm on wing panels ect ) and then glued into place using cyno.
lifeboatpaul
Re: SEA IMP build
« Reply #3 on: April 15, 2010, 07:54:22 am »
2x 550 motors and 5" prop shafts fitted, two 40mm props
Kort nozzles were made from spray tin lids, held in place by filler at the base and brass rod cages
lifeboatpaul
Re: SEA IMP build
« Reply #4 on: April 15, 2010, 07:56:55 am »
Rubber wraparound bumper made from car fan belt , slots cut in to help with the contours.
lifeboatpaul
Re: SEA IMP build
« Reply #5 on: April 15, 2010, 07:58:06 am »
Deck fitted.
lifeboatpaul
Re: SEA IMP build
« Reply #6 on: April 15, 2010, 07:59:34 am »
Wheel house nearly complete made from 1.5mm styrene sheet, 70mm hole in roof cut to accommodate speaker for sound unit.
Re: SEA IMP build
« Reply #7 on: April 15, 2010, 08:12:59 am »
Are you steering using the props ?
lifeboatpaul
Re: SEA IMP build
« Reply #8 on: April 16, 2010, 09:24:46 am »
Hi , yes I will be using a Action p94 mixer/ ESc unit , I will fit the rudders but they will be fixed , for show only.
Paul.
mike_victoriabc
Re: SEA IMP build
« Reply #9 on: April 17, 2010, 01:42:34 am »
Ray's Freewinds is a Sea Imp hull - should be photo's here.
I have a plan of the Sea Imp but you're past that stage - also a few photos of variations of it.
lifeboatpaul
Re: SEA IMP build
« Reply #10 on: April 25, 2010, 01:37:11 am »
Started to paint the model now, starting to look like a Sea Imp now.
Paul
lifeboatpaul
Re: SEA IMP build
« Reply #11 on: April 25, 2010, 01:38:47 am »
Some of the detail now added.
Paul.
Re: SEA IMP build
« Reply #12 on: April 25, 2010, 08:13:55 am »
Why is the"mast" such a heavy structure?
Del-boy1958
Re: SEA IMP build
« Reply #13 on: April 26, 2010, 10:05:15 am »
Hi Martin
I think there is a drivers position on the roof and the mast provides shelter.
Paul will no doubt correct me if I am wrong.
Del
Sechelt Bob
Re: SEA IMP build
« Reply #14 on: April 26, 2010, 08:53:44 pm »
Just for your info, the 'Imp' boats vary in length from 25' to 50', depending on which boat it is. The latest tug, Sea Imp IX measures 53'-6"x24'4x11' -6" and is powered by twin 500 HP diesels, giving a speed of 10 knots.
Good luck with the model.
lifeboatpaul
Re: SEA IMP build
« Reply #15 on: April 27, 2010, 04:26:00 pm »
Hi Martin
Del
A red rag to a bull Del !   of course I will correct you !
The" heavy looking mast " as Martin puts it is part of the superstructure that has the Radar mounted on it above the skipper when using the upper wheelhouse position , the other reason for this is that the very tall mast with tow indicating lights etc.. is on a pivot within the raised superstructure so it can be lowered back towards the stern to get under low brigades etc , handy for the us modellers to -it will take up less room to store .
Haven't done much more to it in the past few days as Ive been getting boats ready for the "  May month of shows" Beale park ,merstram,Wicksteed and Alfold and if possible  day at Old Warden on the only weekend left  (8 +9th )!
Paul
alan colson
  • I Just Dabble In Model Boats
Re: SEA IMP build
« Reply #16 on: April 28, 2010, 08:33:21 pm »
When you come to Alfold Paul have a look at the Hanwell & district stand, if Len Lewington is there I feel sure he will have his Sea Imp models on display, he may also be at Merstham.
Alan
ray123
  • shuswap tugboat
Re: SEA IMP build
« Reply #17 on: April 28, 2010, 10:04:38 pm »
i missed this one %) paul thats a nice little boat your building  well done   no dout see you at one of the shows
regards ray
lifeboatpaul
Re: SEA IMP build
« Reply #18 on: May 25, 2010, 10:17:18 pm »
The sea Imp is now finished it had it,s maiden voyage at the Merstram show the other week ,, it didn't go to well at all, I didn't fit ant rudders as I thought that the action ESC/mixer unit would do it all for me but with the tug only measuring 13" long the controls were way to fierce and It wanted to spin all the time .
So Del and I had a re-think on the way back and agreed that I would need to fit rudders with external linkages as there is no room inside and no access to the inner stern area.
Rudders were made from plasticard and brass tillers were fitted a small bore model aircraft snake/bowden cable was fitted, the Action mixer/ ESC unit was removed in favour of a single M-tronics ESC ,micro switches were fitted to the steering servo to cut one motor on each side when full rudder is thrown.
success! Last Sunday morning at our local boating lake I sailed it again and it handled fine , I will be using it at the forcoming shows ( wicksteed, Alfold, wings and wheels) if any one wants a look /chat about it.
Paul.
alan colson
Re: SEA IMP build
« Reply #19 on: May 27, 2010, 07:28:16 pm »
Well done Paul, I know you where disappointed with it at Merstham, look forward to seeing it again at Alfold.
Alan
Re: SEA IMP build
« Reply #20 on: May 27, 2010, 07:56:34 pm »
Is it coming to Wicksteed?
 If so, bagzie first go!  :-)
lifeboatpaul
Re: SEA IMP build
« Reply #21 on: May 27, 2010, 10:48:58 pm »
Martin - of course! ,Ill have to give you a lesson in using my graupner mc 24 TX first.
See you Saturday
Paul.
mike_victoriabc
Re: SEA IMP build
« Reply #22 on: May 28, 2010, 02:03:51 pm »
Lot of boat there in 13 inches!
Looks good -
Good luck with your next run in the pond.
octo
Re: SEA IMP build
« Reply #23 on: May 28, 2010, 06:07:37 pm »
what an good looking tug , well done:-))
yours  Tony
tugs46
Re: SEA IMP build
« Reply #24 on: June 04, 2010, 04:11:37 pm »
Nice work!!!!
I like it :-)) :-))
Much like 'puffin's model "Bulfrog", over on the model tug forum.
Page created in 0.603 seconds with 17 queries.
