Author Topic: Worlds Largest Electric Plane.  (Read 879 times)
« on: April 21, 2010, 06:22:15 pm »
Modelmaker Tony Nijhuis has built the worlds biggest electric powered model aircraft
Built by Tony Nijhuis in his garage the aircraft is a scale version of the US bomber and has a 20ft wingspan and weighs just over seven stones
Enlarge   Modelmaker Tony Nijhuis has built the worlds biggest electric powered model aircraft
It has 96 batteries that power four electric motors which drive the aircraft to 40mph along a 50m runway before it takes off
HOW B-50 MEASURES UP
Powered by: 96 batteries
Wing-span: 20ft
Cost: 8,000
Weight: 100lb
Speed: 40mph
The 46-year-old model-maker has spent 30 years making model aeroplanes and decided to create an electric version of the 1950s bomber from scratch.
It has 96 batteries that power four electric motors which drive the aircraft to 40mph along a 50m runway before it takes off.
It can then fly for eight minutes in the air before it has to descend so the batteries can be recharged.
Made from balsa wood and plywood, the plane also has workable bomb bay doors and pneumatic landing gear.
It is restricted to 400ft, but after the volcanic ash cloud grounded aircraft Tony has been making the most of the empty skies.
The plane is 7:1 scale model and has entered the record books after being launched.
The father-of three, who works as a consultant engineer, said: 'This is the heaviest electric model aircraft in the world.
 'The bigger the planes are the easier they are to fly. This has elevator control, rudder control, pneumatically operated under carriage and the bomb bay doors open and could drop real bombs, if you wanted'
'It's a model of the Boeing B-50 bomber that was used from the 1950s to the 1970s. It's all scratch built and has a wingspan of 19ft.
'It weighs just over 100lb and is powered by four, four kilowatt electric motors and each motor has 24 batteries powering it. The propellers have a 2ft diameter.
'I've been working on it on and off for the last two years and made it in a single garage.
'It comes in eight pieces and has to be bolted together.
'The bigger the planes are the easier they are to fly. This has elevator control, rudder control, pneumatically operated under carriage and the bomb bay doors open and could drop real bombs if you wanted.
'However, unlike smaller models, if this crashed it would disintegrate.
'Because of its size it is classed as a light aircraft and had to be tested by the Civil Aviation Authority and requires a certificate to fly it at public shows.
'We can only fly it for eight minutes because the batteries need charging and there is an alarm to let us know when the time is running out.
'But full size electric planes are being developed; the power is there, it's just that it needs to be sustained for longer.'
Read more: http://www.dailymail.co.uk/news/article-1267783/Chocks-away-worlds-biggest-model-aircraft---shame-8-000-B-50-bomber-fly-8min.html#ixzz0lkvQl0G7
http://www.youtube.com/watch?v=jFSOMzTromM&feature=player_embedded
andyn
Re: Worlds Largest Electric Plane.
« Reply #1 on: April 21, 2010, 07:29:16 pm »
Good old Tony, had the pleasure of speaking to him at the Barkston Heath Nats a couple of years back. All his models are something to behold.
