Author Topic: electrics problem  (Read 5972 times)
bosun
    • bosunsmodelboats.com
electrics problem
« on: January 03, 2007, 11:14:10 am »
Hi Guys ,
Can anyone help me out with this problem,,I am trying to set up the electrics in a model of an ocean going steam tug, that is 44 inches long by 13 inchers beam so it is quite big.. I am using an Acoms 2 channel Tx to an Acoms Rx, bought complete and new. I have installed a 550 motor running on 6 volts going to a 6omm prop, so far so good. When I push the forward control lever on a bench test  the prop rotates ok, when it reaches halfway it slows down and gets a bit erratic, When I pull the lever to go astern there is no response,  I have tried various battery set ups from 6 volt , 7.2. through to 12, it is the same, I have put the rudder servo into into channel 2 and it works fine, I have changed the ESC from a Ripmax Extra  that was recommended from the shop, to a Futaba, the problem is still there, and its driving me nuts . Any help would be apreciated, sorry for the long question.
Happy new Year to all.
Bosun
Telstar
Re: electrics problem
« Reply #1 on: January 03, 2007, 12:22:45 pm »
Hi Bosun,
Happy New Year.
With your problem, are you using BEC to power your receiver or a separate battery (or inadvertently both)
I would take the Rx and battery out on to the bench (a different motor saves removing the one in the tug) and rig it up to test. If you are using a Rx battery separate, you should have disabled the BEC on the ESC, I do this by disconnecting the red wire between the Rx and ESC. Asking the obvious are you setting up with the throttle in the mid travel on your Tx (some ESC's self set on switch on)
If you think I can help send me a PM
luck Tom
FullLeatherJacket
« Reply #2 on: January 03, 2007, 01:41:05 pm »
Bosun
It might be the ESC which isn't suitable. Check the type you have against this table; some don't have a reverse while others have the facility to disable it.
http://www.futaba-rc.com/radioaccys/old-speed-controls.html
On another tack, are you using a geared motor? A 550 on direct drive to a 60mm prop sounds a bit heavy-going for the motor in a big model like this one. Anyone else have any experience of such a set-up?
Doc
« Reply #3 on: January 03, 2007, 05:33:37 pm »
Bosun,
First, does your ESC have a reverse to start with?  Dumb question, but I've done things 'dumber'.
Then, check the current handling capacity of the ESC as compared to the motor.  If the ESC's ratings aren't higher than the motor's, that would be the problem, I'd think.
And then, the 'start up' procedure (if any).  Throttle at 'neutral' at 'turn on', and then it depends on the ESC.
And check all the wiring/connections.  Anything getting sort of 'warm-ish'?  And are the connectors tight?
[Used some of the 'bullet' type connectors with a plastic 'sleeve' that covered the connection when connected.  Didn't pay enough attention and 'thought' it was connected when it actually wasn't (sleeve was harder to make slip on than I thought).  Things fine till the plastic sleeve heated up a bit, expanded, broke the connection.  When it cooled it contracted, made connection, things worked fine.  The language I used would get you thrown out of any of the lowest 'dives' (bars/pubs) around here!]
Good luck!
 - 'Doc
bosun
« Reply #4 on: January 03, 2007, 07:01:28 pm »
Hy Guys.
 Thanks for the quick replies to the electrics problem, to be honest it has restored my faith in the modelling community, I was ready to pack it all in before I had even started.  I took the advice of Telstar first and did a bench test with a different motor, I had the same problem, no reverse, Then as full leather jacket suggested I had a look at the ESC ( this was the second one that I had tried) and was bought from a local model shop just before xmas, I had no reason to think that it would be the problem as the guy in the shop assured me that it was what I wanted, still I had no reverse. I then decided to take a run into Cardiff to a different model shop and buy ANOTHER esc , once again being assured that it was what I needed, I have just done another bench test and it is all working, and believe me it feels good. I have tried it in the bath, and although there is a bit of a wash, it does,nt seem to much as there is,nt any ballast in her yet,  or anything else for that matter.  I am now going to take Docs advice and spend the rest of the evening checking all the wiring and fittings.
One other things I have learned is never to take on board any advice, from some one who works in a model shop, that only stocks Cars , Hedlecopters, and Planes, but no Boats.  Once again from a complete novice to modelling many thanks.
Bosun
Tug
« Reply #5 on: January 03, 2007, 07:36:01 pm »
Purely on the motor suitabillity, a single 550?
Nah my big tug is 46" x 12" its a 30 volt motor and I run it on 24 volts x30 amp electronize 3 1/2" prop and she runs good, in any weather
(I would suggest a 550 on 12 volts would have no chance ((I use a 550 geared in my Drifter on 6 volts thats good))
But its damned heavy ballasted to lift in and out of the water [even with flat batteries] the run-up to speed in foul weather is good and  of satisfy-ing performance particularly when trying to force a turn against the wind around a jetty etc.
The electrics.. If your running a bec setup, as the draw from the batteries increases  [motor wants more amps] the voltage decreases to a drop-out situation thereby switching off the speed controller [or the Rx. ] same effect motor stops.
so 6 volts is a no-hoper, I know;  thats what happens with my drifter, when I forget to oil the propshaft the lights go dim and motor shuts down. Flippin eck, can't I ramble on?
Junk is something you've kept for years and throw away three
 weeks before you need it.
FullLeatherJacket
« Reply #6 on: January 03, 2007, 11:38:21 pm »
Bosun
Glad to have been of help. I use ACTion speed controllers for all my models - no commercial connection; they're just very good kit and Craig Talbot is a 100% customer-focussed bloke. Not that you need yet another ESC but something to store away for later, maybe?
As Tug has confirmed, I think a geared 550 on 6 volts would be better than direct drive. My Envoy (Model Slipway kit) is about the same size as your model and runs very well using a MFA Torpedo 500 geared at 6:1 on 12 volts. Alternatively they do a 2.3:1 gearbox and motor for 6 volt operation.
As always when I wax lyrical, please feel free to suit yourself, but it's a b100dy shame you had to learn the hard (i.e. expensive) way about non-specialist model shops. I can usually tell by their eyes if they've understood a word of what I've said. If I find myself pointing to things on shelves or waving my hands around while trying to describe something then I know I should have gone elsewhere!
bosun
« Reply #7 on: January 04, 2007, 07:30:23 pm »
 Thanks guys for your help.
 This morning I ordered a MFA torpedo 500 motor with a 6.1 gearbox from  Weastbourne Models, thanks to Full Leather Jacket in pointing me in the right direction, with a bit of luck it will be here tomorrow, I have been down to Swansea today and took a load of pics of the Canning, an old steam tug converted to diesel, I used to work on a few tugs that were very similiar to her when I was a kid, The Dunhawk, Dunheron, and the Dunfalcon, out of Newport, I believe that the Falcon was the largest tug of her type working the Bristol Channel at that time early sixties. Although I have been around boats/ships all my life, working up from a UDH, EDH, AB, Bosun, and skippering my own commercial fishing boat, things are different when trying to convert to Radio control, so once again I am starting on another learning curve and I am back to being a UDH (Unclassified Deck Hand).
Bosun
« Reply #8 on: January 04, 2007, 08:36:06 pm »
Well you are now a 'Leading Seaman' according to 'Mayhem'
When are you coming round for a cup of tea.   :)
Cheers...Ken
bosun
« Reply #9 on: January 04, 2007, 10:19:35 pm »
Hy Ken,
How you doing, how,s that boat of yours coming on,, I will be around for that cuppa, I have been busy over xmas with the Country Music scene, extra gigs and stuff, bit quiet for now as usual this time of year, so you might just find me knocking on your door, thing is being a tug man I will probably have the Mrs in tow.
Bosun
« Reply #10 on: January 05, 2007, 11:29:48 pm »
Hi Bosun
I'm up to the cabin construction.   My,  it's very delicate stuff    ;D
Have to fit it in between actual company work all weekend. Never mind, I'll find the time
Cheers...Ken
Page created in 0.012 seconds with 20 queries.
