Pages: 1 [2] 3   Go Down
Author Topic: Yamato jinks8  (Read 24762 times)
jinks8
Re: Yamato jinks8
« Reply #25 on: July 22, 2010, 04:23:24 am »
Hear are a few pic’s of the deck and sum more of the guns will have more of the full deck later At the blunt end in the build photos of the hull  near the hanger deck they have just cut  it at 45 degrees as in  fig 1 but in the book on the Yanato it shows that it is stepped down as in fig2 and the photo they may chang it later. The water proofing is Thompson’s clear water seal later it will be given a few coats of satin varnish        [ the water proofing is Thompson’s clear water seal later it will be given a few coats of satin varnish
jinks8
Re: Yamato jinks8
« Reply #26 on: July 29, 2010, 09:57:33 pm »
The deck and hull are just about dune sum photos  and a vid  of the props and ruder        Have had inquiry about the motors I have used I got mine form robot bits        http://www.robotbits.co.uk/motors-gearboxes/cat_2.html but you can also get them from https://secure.precisionmicrodrives.com/index.php
jinks8
Re: Yamato jinks8
« Reply #27 on: August 08, 2010, 07:11:49 pm »
sorry chaps never got to put it on the water but will try again later
jinks8
Re: Yamato jinks8
« Reply #28 on: August 13, 2010, 05:26:19 pm »
New build by Grand son and partner finished to day sailing weight 8lb 7oz
jinks8
Re: Yamato jinks8
« Reply #29 on: August 26, 2010, 05:35:21 pm »
sorry no movement on this at the moment as no got next lot of parts yet. Trying to fined out y <*<
jinks8
Re: Yamato jinks8
« Reply #30 on: September 16, 2010, 02:07:51 pm »
got parts 11/12 so will have more on duild later have to get new laptop first doing tthis on my phone hope it will not be to long
jinks8
Re: Yamato jinks8
« Reply #31 on: October 21, 2010, 06:31:17 pm »
Sorry it has bin so long but had a lot of things to do but an starting to get in to building again hear are sun pick’s of issues 11& 12. Got voated best boat for this year by club members for my Bismarck chufet to bists                               A bit out off focuses but had to use my phone
jinks8
Re: Yamato jinks8
« Reply #32 on: October 21, 2010, 06:36:38 pm »
hear are photos of issues 13/14        53 should have around bit as in 54
jinks8
Re: Yamato jinks8
« Reply #33 on: October 27, 2010, 02:11:13 am »
Hi gentle builders of the Yamato more pick’s of my build .covered the barrels so get on to pick’s of the rest of the guns so far they are stuck on to painting board with dubbel sided sticky backed plastic        Have started to put the rails on to the flight deck for this I got sum straighter rod   model shop for better fit. I t was then treated with Car’s metal conditioner and Carr’s metal black cut to length and glued in with cryo        All so dune the underside of flight deck not to specks as it has to be removable but wanted to give sum definition and a hint of the rails and brackets        [IMG]http://i149.photobucket.com/albums/s78/jinks8/Yamato/Picture026Small.jpg[/IMG
jinks8
Re: Yamato jinks8
« Reply #34 on: October 27, 2010, 07:10:34 pm »
God this must be the longest 1 page poast on the site. Got all the rails and turn tables on the flight deck and the ladders and platforms on the bridge tower £%$&**just cut my thumb blood all over the place ho well first time on the Yamato glad got deck sealed        all so got the stack put together        Stack and guns not fixed yet
jinks8
Re: Yamato jinks8
« Reply #35 on: October 28, 2010, 09:55:42 pm »
 Started to drill scuppers and put on what they are calling the load line. This not a load line but a Degaussing cable and has sum thing to do with magnetic mines? I have not  cut the plans sent but stuck low tack tape on to them and traced the scuppers and Degaussing cable on to it then stuck it on to hull hope the pics will make it clear. I have used Tamiay 18mm it sticks firmly to the paper but can still be peeled off. One word of warning  use short lengths to long and it will be hard to control        The filler on the bow photo 5 is to fill scuppers as they did no look wright in fact a complet mess
jinks8
Re: Yamato jinks8
« Reply #36 on: October 30, 2010, 09:27:31 pm »
hi it has bin kindle brought to my attention that the degaussing coil around most of the ship is squire not round so hay presto well not that quick most of to day one round coil is with a lot of cryo and filing is now a squire box well i think it is
jinks8
Re: Yamato jinks8
« Reply #37 on: November 03, 2010, 03:35:08 am »
started to do the exhaust pipes
jinks8
Re: Yamato jinks8
« Reply #38 on: November 06, 2010, 02:01:57 am »
Had a rest from sanding filing  and started to do sum of the lighting so t was drilling hols and soldering wire LEDs and capacitors        The switching gear will be I hope got next Sunday from Hunter’s so it can be turned on and of by remote so as yet on photos of  it yet the LEDs are from http://stores.ebay.co.uk/Goodwill-Leds-Sales  they cum with the correct capacitors
Perkasaman2
Re: Yamato jinks8
« Reply #39 on: November 06, 2010, 11:27:24 am »
You are a hero...................... your courage and tenacity are beyond question. Well done! You deserve a mention in' Martin's Mayhem Despatches'  :-))
jinks8
Re: Yamato jinks8
« Reply #40 on: November 07, 2010, 11:37:40 am »
Thanks Perkasaman that is nice of you By the way is anyone going to the show next week end will be thire on Sunday
jinks8
Re: Yamato jinks8
« Reply #41 on: November 20, 2010, 03:32:01 am »
Hi gentlemen well could not put it of any had to get the spray gun out and start putting sum detail on the con tower        The rear control bridge well the start of it        and the props from prop shop        the paint is 164 Humbrol dark gray it looks liter than it is
jinks8
Re: Yamato jinks8
« Reply #42 on: November 22, 2010, 01:03:45 pm »
This is the contents of packs 15/16        and that concludes the lesson for to day
jinks8
Re: Yamato jinks8
« Reply #43 on: November 24, 2010, 12:46:33 am »
Good morning gentle men a few more photos of the super structure  have bin trying to get up to the pond at brid but whether has not permitted it so had it in bath and it moved not far but it hit the bath forward and aft rain or no rain on Thursday I an going to put it on the water so should have vid by Friday
jinks8
Re: Yamato jinks8
« Reply #44 on: November 27, 2010, 03:07:51 am »
the sea trails did not go well it moved but not at a good speed infact it was slow and the stering was no good due to the low speed. So had to modifye it and put 2.speed 280tis in    The reason there is no vid was the whether  not there long enough to get sum. Now for the modifications as I stated the 2 outer motors are now 280tis         to get them in I had to cut sum of  the supports on the port and starboard    you can see this in the photos because this may weaken the hull put extra supports in to the side   Putting the new motors in the problem was to connect them to the shafts this was done with sum tubing made for the job   you can get it and the motors from   http://www.alwayshobbies.com [/url]      The weather was bad snow and windy not a good combo for filming but now the mod’s are dun will try again. Once more sorry to if you have dun it with the small motors the conversion is not hard to do as the 280tis will fit with out having to move the shafts but it must be the 2 outside motors
jinks8
Re: Yamato jinks8
« Reply #45 on: November 28, 2010, 05:40:50 pm »
You will have to forgive this as first time used vid on phone and got it upside down but if you can stand on your head it's ok        copid this of laptop screen        Promise to get it better next time will get grand daughter to come and do the vid bit as it is hard hoalding phone and getting a ship on twin stick to go
Proflooney
Re: Yamato jinks8
« Reply #46 on: December 06, 2010, 08:33:44 am »
hi i just got onto this forum and started reading some threads. you mentioned the sticky with some resins. that is the styrene they add if it is polyester resin. they add it to help it cure nice and hard. its kinda like a waxy substance.. I use to be plant manager at a bassboat factory so spent a lot of time messing with  resins. you can either just sand it off which it gumms up a few sheets or we uses to really wet up rags with acetone and just wipe the styrene off it doesnt affect the resin. another way is we would just dust talc over it and ignore it.
joe
jinks8
Re: Yamato jinks8
« Reply #47 on: December 06, 2010, 11:54:24 pm »
thanks for that Profloony is nice to have pepole that can give info on such things will know next time and not wast so much sand paper
Proflooney
Re: Yamato jinks8
« Reply #48 on: December 11, 2010, 03:11:03 am »
any more pics? lol im getting ancy to start mine but I have to figure out how to finish the hull in delftship. I am still deciding whether to go 1/72 scale or 1/96 such tough choices lol but like wife says first I have to design the hull plans so I can CNC a foam plug
Joe
jinks8
Re: Yamato jinks8
« Reply #49 on: December 11, 2010, 11:47:40 pm »
just got parts 17/18 today so will have more soon. Putting props and motors in a rebuild of the USS Missouri at the moment may start a build log not made up my mind yet still a lot to find out as have no plans yet and there is a lot missing but more picks of yamaot today or Monday
Pages: 1 [2] 3   Go Up
