Author Topic: What grease?  (Read 9144 times)
hazmat
What grease?
« on: May 06, 2010, 03:45:01 am »
Being VERY old school (well past the sale by date) , I've always used Vaseline to pack my prop and rudder shafts but I'm trying to bring myself up to date and have been told that the 'modern' trend is to use oil  {:-{ ?!?
Could you please advise me :-
1/ What grease or oil does everyone use for packing prop shafts and rudder tubes? and
2/ if you use oil, do you need to fit rubber seals to prevent the oil leeching into the water?
Thanks, Paul
FullLeatherJacket
Re: What grease?
« Reply #1 on: May 06, 2010, 08:21:16 am »
Waxoyl (usually used for rustproofing underneath of car bodies).
FLJ
Re: What grease?
« Reply #2 on: May 06, 2010, 08:24:59 am »
FullLeatherJacket
Re: What grease?
« Reply #3 on: May 06, 2010, 09:55:03 am »
Prop shaft grease.
http://www.cornwallmodelboats.co.uk/acatalog/prop_shaft_accessories.html
Seven and a half quid  fior that little tube? Don't you ever try playing the poverty card again, Richard!  <:(
FLJ
PMK
Re: What grease?
« Reply #4 on: May 06, 2010, 10:24:18 am »
Just out of curiosity, what is wrong with using Vaseline anyway?
Re: What grease?
« Reply #5 on: May 06, 2010, 10:38:18 am »
I suppose it depends on what you are suffering from. They say KY jelly is a good substitute....
As far as boats are concerned Vaseline is too stiff and saps power. Everyone seems to have their own preference in this line, no two of us seem to agree. I use motor oil on the basis that it is designed for fast moving metal to metal contact and creates no drag but as our friend FLJ says - suit yourself.
FullLeatherJacket
Re: What grease?
« Reply #6 on: May 06, 2010, 10:39:22 am »
A bit too thick, my man - certainly for this particular purpose  %)
FLJ
(That man Bishop is just plain rude!!)
J.beazley
  • The building never ends
Re: What grease?
« Reply #7 on: May 06, 2010, 10:39:53 am »
Vaseline is water based and breaks down over time i think aswell PMK.  :-))
nothing wrong with using motor grease as long as its not too thick to cause drag on the shafts.
Jay
PMK
Re: What grease?
« Reply #8 on: May 06, 2010, 10:50:16 am »
Ah, right. So it's too thick, creates drag and it's water based.
Thanks for the heads-up.
Where can I buy Waxoyl?
nda3500
Re: What grease?
« Reply #9 on: May 06, 2010, 11:23:13 am »
What about that black grease they use for CV joints on cars.   Seems to be quite thin stuff.
Re: What grease?
« Reply #10 on: May 06, 2010, 11:40:50 am »
  Scrape it orft a sheep, basically lanolin disolved in parraffin.
  Strange that one FLJ, cos once the parraffin starts to dry off the "Grease thickens up"?
 CV joint grease contains Molybdedendum disushics -- Black Moly -  runs quiet with that in the tube. Mix yer own similar by using Castrolese (or whatever they call it now) H/T wheel bearing grease and add Graphite.
Martin [Admin]
Re: What grease?
« Reply #11 on: May 06, 2010, 11:44:18 am »
Cheapest grease you can find in your local car spares shop....
Re: What grease?
« Reply #12 on: May 06, 2010, 01:02:35 pm »
FLJ
If I played the poverty card Dave I would not shop with you  {-)
That little tube has lasted 16 boats over the last 4 years. Not bad I think.
FullLeatherJacket
Re: What grease?
« Reply #13 on: May 06, 2010, 01:04:23 pm »
:P
FullLeatherJacket
Re: What grease?
« Reply #14 on: May 06, 2010, 01:05:34 pm »
Never mind the theory - it just works (for me and several others).
FLJ
Re: What grease?
« Reply #15 on: May 06, 2010, 01:06:08 pm »
Its water soluble Dude
andyn
Re: What grease?
« Reply #16 on: May 06, 2010, 01:06:15 pm »
Halfords LithMoly CV grease is the best we have found. A single 500g £5.99 tub will outlast you oldies...
Re: What grease?
« Reply #17 on: May 06, 2010, 01:10:51 pm »
Halfords LithMoly CV grease is the best we have found. A single 500g 5.99 tub will outlast you oldies...
Watch it sonny !!!
Re: What grease?
« Reply #18 on: May 06, 2010, 02:09:39 pm »
I suspect that the fact that everyone has their own favourite simply demonstrates that anything oily will work within reason. Just that if you stuff the tube with thick grease you will greatly reduce your battery life or worse.
PMK
Re: What grease?
« Reply #19 on: May 06, 2010, 03:00:02 pm »
Peace and love, brother.
BJ
Re: What grease?
« Reply #20 on: May 06, 2010, 05:09:03 pm »
Try COPPER EASE. Works from -40C to +150C. Water resistant and sticks like the proverbial ****.
poddy
Re: What grease?
« Reply #21 on: May 06, 2010, 07:02:29 pm »
Has anyone tried the stuff the big boys use? Or would that not be pc?
http://www.marinescene.co.uk/category/520/grease-amp;-lubricants
Is the stern tube what I've been calling the prop shaft?
At the risk of being too nerdy, doesn't the viscosity you need depend on the rpm of the shaft and the tolerance/condition/material of your bushes?
Vaseline does sound pretty eco-friendly, if it doesn't disolve too quickly
I think that's about two-penneth worth.
BarryM
Re: What grease?
« Reply #22 on: May 06, 2010, 07:07:39 pm »
The stern tube is what the prop shaft runs in.
Barry M
poddy
Re: What grease?
« Reply #23 on: May 06, 2010, 07:12:42 pm »
Thanks for that Barry.
Martin [Admin]
Re: What grease?
« Reply #24 on: May 06, 2010, 07:21:13 pm »
Do you mean this stuff?   %)
http://www.screwfix.com/prods/22070/Sealants-Adhesives/Adhesives/Grab-Adhesives/High-Performance/Sticks-Like-Sh-t-290ml
