Author Topic: Electric start  (Read 4753 times)
kiwimodeller
Electric start
« on: May 09, 2010, 11:20:44 am »
Greetings all, has anybody experience with using an electric motor to restart a steam engine? I have seen it done but did not take much notice at the time. I have a Gage VR1A single cylinder 1/2" bore by 5?8" stroke. It is reversable but of course may not restart if it stops at top or bottom centre. I have a spare radio channel and room to fit a small electric motor which I thought I would connect to the flywheel with an O ring. Can anybody suggest how big a motor I might need and what reduction ratio? Thanks, Ian.
Re: Electric start
« Reply #1 on: May 09, 2010, 11:55:57 am »
Just a thought Ian.........how about a flywheel with serrations on the VR1A engine & a servo to joggle the serrations until a steam start is made .... :o - Derek
doubletop
Re: Electric start
« Reply #2 on: June 16, 2010, 11:50:56 am »
Leave it permanently belt drive connected and use it as a generator to keep the battery re-charged?
As for size and torque it would be in the try it and see category if the belt drive went to the large diameter on the flywheel and you used a small pulley on the motor you may get away with a pretty small motor
Re: Electric start
« Reply #3 on: June 16, 2010, 11:57:20 am »
July/August 1986 "Radio Control Boat Modeller" A Barring engine for a Stuart 10V
 And not sure if "Bogstandard" showed in effect a tumbler type mechanism for starting on this forum.
   Regards  Ian.
doubletop
Re: Electric start
« Reply #4 on: June 16, 2010, 12:06:09 pm »
In can't find any posts from Bogs on this forum but he's around as he pointed me to this forum yesterday. If you want I can PM him on the other forum?
kiwimodeller
Re: Electric start
« Reply #5 on: June 17, 2010, 11:39:41 am »
No problem, at the moment I am proceeding in fits and starts with the installation (see my other post) and then when it is up and running I will work on the electric start if it is needed. I have put a reversable prop in the boat instead of using the engine reverse so I may not need the starter but it would be an interesting thing to do anyway. Cheers, Ian.
Page created in 0.462 seconds with 17 queries.
