OK i have a question how do i get the motors out, i have borrowed an esc off a tug from the local pond , niether motors work probly sound rough an loud
there the mfa type looks like they were put in before the deck went on an i cant get all four screws out?
any ideas i want to pull but risk brakeing the boat
Most motors sound rough and loud when the boat is out of the water.
If you have to get them out, and need access to the screws on the outside, then a
couple of strategically drilled holes to fit the screw drive may be necessary. The holes can
be patched later from the under side, then filled, or plugged with a dowel and epoxy after
the motors are put back in place.
If possible, try to loosen the two inside screws, then loosen the u-joint disconnecting the motor to
the shaft, and see if the motors can be slid out of place...
