Author Topic: Plans required  (Read 6745 times)
kiwi96
Plans required
« on: May 11, 2010, 11:22:54 am »
Hi. Was wondering if any one here can point me in the right direction. Looking for plans so can build an ice breaker of the type in the links.
http://www.casr.ca/bg-icebreaker-svalbard.htm
http://www.marinetalk.com/articles-marine-companies/art/Norwegian-Coastguards-First-Icebreaker-DNV00955403IN.html
http://en.wikipedia.org/wiki/NoCGV_Svalbard
http://portal.fma.fi/sivu/www/baltice/jaanmurtajalista.pdf
Just that being her in NZ where it is a warmer climate, we do not see these vessels so I do not know where to start.
Any help appreciated.
Cheers,
Adrian.
Klunk
Re: Plans required
« Reply #1 on: May 11, 2010, 05:16:08 pm »
IO have a set of plans for ice breaker "Norman Mcleod Rodger" from |Marine Modelling International plan no MAR3406 IF THATS ANY HELP!
full time penguin
Re: Plans required
« Reply #2 on: May 11, 2010, 06:14:12 pm »
I don't think this helps (and I'm very rarely helpful  %) ) but Graupner used to make a Icebreaker kit called the Kontio.
http://www.msh-modellbau.de/index.php?sTemplate=ViewModellDetail&iRubrikID=8590&iAktModellID=74
Umi_Ryuzuki
Re: Plans required
« Reply #3 on: May 11, 2010, 09:13:23 pm »
Kontio kits are a bit of rare breed these days... Seems like there were two on the Wants and Swaps a month or
two ago... I did a bit of searching, and came up with the following image...
Can't be completely accurate, but it's a start...
shipmodeler2008
Re: Plans required
« Reply #4 on: May 11, 2010, 10:47:52 pm »
Hi there,
Yes I'm the one looking for the Norwegian Icebreaker plans on behalf of my client. He has moved on from trying acquire a Konito as they seem to be totally unavailable now. Even 2nd had it's a tough ask. I guess if any of your Norwegian Coast Guard members are able to shed light I would be most appreciative. Cheers, Graeme
shipmodeler2008
Norwegian Icebreaker cont.
« Reply #5 on: May 11, 2010, 10:54:42 pm »
Hi Umi.
Any longitudiinal lines for this? Cheers, Graeme
Umi_Ryuzuki
Re: Norwegian Icebreaker cont.
« Reply #6 on: May 12, 2010, 02:31:24 am »
Hi Umi.
Not yet, but if I, or someone, can come up with a profile for the ship, or it's sister/cousin ships, then
 I can probably work out the general placement of those lines....   ok2
shipmodeler2008
Norwegian icebreaker profile
« Reply #8 on: May 12, 2010, 03:56:49 am »
Here is a shot of the Norwegian Icebreaker that I'm looking for hull lines etc. etc. cheers, Graeme
Umi_Ryuzuki
Re: Plans required
« Reply #9 on: May 13, 2010, 12:37:52 am »
Okay, Definitely not accurate, but the best overlay I can produce with the two pieces above.
The hull lines don't quite seem to account for the Ice breaking keels.
This is my best guess...  ;)
I accounted for  (4) frame #10 amidship.
That would be the most outside line on each side of the frame plans.
shipmodeler2008
Icebreaker lines?
« Reply #10 on: May 13, 2010, 09:28:37 pm »
Umi.
Brilliant. Thank you. I will take all this and talk with a 3 D company. cheers, Graeme O0
Page created in 0.033 seconds with 21 queries.
