Author Topic: ACOMS AP202  (Read 5114 times)
glenpens
ACOMS AP202
« on: January 06, 2007, 06:06:38 pm »
I have a acoms AP202 consisting ofTRANSMITTER,BEC RECEIVER. 2 Servo ,switch and a Battery I want to now fit this to my boat that has already got the 2 motors and props fitted. Any ideas how to wire it, do I need a speed controller. ect
Glen
Re: ACOMS AP202
« Reply #1 on: January 06, 2007, 11:31:49 pm »
Yes you do need a speed controller ,but before we get into that territory what is the boat and what are the motors
glenpens
Re: ACOMS AP202
« Reply #2 on: January 07, 2007, 09:43:34 am »
The WARSHIP is the HT2877 which I am trying to mod. I believe the engines are twin 380 racing motors.
The only other way I could do the modis to use a different frequency is to change the chrystals but I cannot identify it on the printed Circuit. Any help will be appreciated
Glen
barriew
Re: ACOMS AP202
« Reply #3 on: January 07, 2007, 01:32:10 pm »
Glen
Can you post a photo of the PC board?
Barrie
(See also my post in the other version of this query on this forum)
glenpens
Re: ACOMS AP202
« Reply #4 on: January 07, 2007, 03:51:07 pm »
Barrie
let me know if you get this poicture ok
Glen
barriew
Re: ACOMS AP202
« Reply #5 on: January 07, 2007, 04:58:33 pm »
Glen,
Can't see an obvious crystal amongst that lot, unless its the large dark green item lower left. If it is, it doesn't look something you could easily replace.
Barrie
glenpens
Re: ACOMS AP202
« Reply #6 on: January 07, 2007, 06:11:52 pm »
Barrie
I think I have bitten off more than I can chew. I suppose I could put everything back to normal and use it as it is.
If I could find out the maker I could ask if they have other PC that I could fit
Glen
barriew
Re: ACOMS AP202
« Reply #7 on: January 08, 2007, 11:41:00 am »
Glen,
I doubt it! Practically all these RTR boats seem to use the same frequency. Your best bet is to see if you can find a local model boat club and see if someone therr could help you. Which part of the country are you in?
Barrie
glenpens
Re: ACOMS AP202
« Reply #8 on: January 08, 2007, 12:54:07 pm »
Barrie
I am going to have a word with Southport Boat club
Glen
glenpens
Re: ACOMS AP202
« Reply #9 on: January 09, 2007, 01:06:44 pm »
I have just come across my manual for the ACOMS. and found this diagramme
Could I replace"A" or "B with my motors?
I have no speed controller as yet what would I need?
Whats the function of the speed controllewr, how does it work?
What are the leads "D" for?
Glen
barriew
Re: ACOMS AP202
« Reply #10 on: January 09, 2007, 01:45:44 pm »
Glen,
B & C are servos. You would normally replace on with an ESC. The diagram shows a mechanical speed controller which would be attached to one of the servos. These are quite hard to find now. The other servo is connected to a rudder - which you dont have :)
The connectors at D are to connect a battery charger for charging the battery.
To reproduce the current setup in your boat you would need two ESCs, one for each motor, and a mixer to mix the rudder signals and throttle signals so you can steer. I'll try to sketch the arrangement and send you a personal message.
Barrie
glenpens
Re: ACOMS AP202
« Reply #11 on: January 09, 2007, 02:13:45 pm »
Barrie
Thanks I am coming to tyhe conclusion that its cheaper to buy a new boat cost wise as speed controllers are dearer
I still think if I could find someone who sells the pc cards complete it would suit me better
Glen
