Author Topic: plannet t5 receiver waterproofing !  (Read 3057 times)
triumphjon
« on: May 12, 2010, 11:52:51 am »
i have a plannet t5 that id like to use in my kyosho seawind yacht ,  with the old 27mhz ive taken out i had the rx inside a balloon to prevent it getting wet . the 2.4ghz has a very short rx lead  will putting it into a balloon impare its performance ?
Bunkerbarge
Re: plannet t5 receiver waterproofing !
« Reply #1 on: May 12, 2010, 12:21:24 pm »
I very much doubt it.  The best answer though is to test it first, probably best done at home.  I have a Spektrum and I've always been amazed at the range but I can't speak for the Planet.
I can't see any reason though why a ballon would affect the reception.
« Reply #2 on: May 12, 2010, 01:15:47 pm »
Thankfully some ballons do   :-))
  Got me coat
The long Build
« Reply #3 on: May 12, 2010, 01:45:05 pm »
Could you not pearce the balloon to let the airial through , would have thought that it would be still pretty water proof , as long as you don't sink..
What about those zip sealing sandwich, freezer bags ?
John Mk2
« Reply #4 on: May 12, 2010, 02:16:02 pm »
Ive found they still work fine in a waterproof box in bubblewarp & stuffed in the bow  ok2
andyn
« Reply #5 on: May 12, 2010, 03:48:05 pm »
I think Mr Long Build's idea is best....
Robert Davies
« Reply #6 on: May 12, 2010, 04:57:35 pm »
I have to admit that I tend to seal my 2.4ghz receivers in whatever small plastic bags that I have available, with some insulating tape, and then velcro that bag to the underside  of the deck - 600yds+ range is not unusual with most 2.4ghz systems.
-Rob
tt1
« Reply #7 on: May 12, 2010, 05:14:59 pm »
Lost the thread a bit after reply 6 Rob (?)  %)
                           regards, Tony.
