Author Topic: New Boat - Battery dilemma!  (Read 2379 times)
TugCowboy
« on: May 18, 2010, 09:41:18 pm »
Ok my wonderful girlfriend has bought me a new boat for the fleet.
Its got no history with it but its in immaculate condition and ready to run bar the battery. The only info I've got is it was run on a 6v battery and it has one of these connectors:
The gap looks like it was made for a SLA battery BUT it is pretty small (13cm x 50cm and 80cm high) so the only battery Maplins sell that will fit is the 6v 1.3Ah one and that seems to be a bit of a low Ah rating. (I know nothing of how this affects the operation, I'm a thicko when it comes to batteries)
Is that going to do the job? Its a twin screw, running on 2 x 400 motors from the look of it and a pretty big rudder
What do the electrickery experts out there think I should be running this beauty on.
Any and all help VERY appreciated.
Alex
Niall
Re: New Boat - Battery dilemma!
« Reply #1 on: May 18, 2010, 10:32:16 pm »
The connector is a "Tamiya" connector. These come in 2 sizes the larger is 14mm x 7mm across the widest part of the connector.
For batteries, and chargers check out this link -
http://www.component-shop.co.uk/index.html
« Reply #2 on: May 19, 2010, 01:52:23 pm »
A 7.2V 5000mAh battery pack with Tamiya connection measures 138mm x 47mm on its side by 24.5mm
http://www.component-shop.co.uk/html/body_large_packs.html
Click on battery pictures to get dimensions etc.
TugCowboy
« Reply #3 on: May 19, 2010, 05:11:34 pm »
Thanks for the replies guys, I've found a 6v 4.5Ah which seems to fit nicely so will change the plug to spade connectors later and see how she runs. A lot happier with SLA's anyway, this things got 2kg of lead inside her right where I'm putting the battery so hopefully it will make a bit more use of the space.
All the best,
Alex
