I'm operating a Sanwa Dash Saber Tx on 27Mhz, my problem is with the throttle stick. It is arranged to give forward and reverse, that is, biased to the centre, but the neutral position does not stop the motor with the Turnigy 30 amp brushed esc which I am using, just slows it right down. I have to hold the stick right down in what would be full reverse (If I was using reverse) before it stops. This means I have to hold the stick down every time I switch the Rx on, or the ESC doesn't arm.
My questions are..
1. Does anyone know how to remove the spring-loading from the throttle stick and use a friction throttle?
2. The Turnigy ESC has a jumper setting for brake on or off, it came set to "off" and I left it at that would changing this to "on" make any difference? (Since I don't know what "Brake" actually means I hesitate to experiment!)
Any advice much appreciated
