Author Topic: Rx power supply  (Read 2556 times)
J.beazley
  • The building never ends
Rx power supply
« on: January 08, 2007, 07:18:07 pm »
could someone be so kind to post a picture of the wiring.
need to figure out what goes where with the Rx power supply and what wires do what??
been running my reciever off the main power pack but want to convert over to having a Rx pack aswell.
cheers
Jay
Faraday's Cage
  • Change is inevitable, except from a drinks machine
Re: Rx power supply
« Reply #1 on: January 08, 2007, 07:49:00 pm »
Hi Jay,
See if this helps. Ive omitted fuses in both motor supply and receiver supply only for clarity.
Terry.
barriew
Re: Rx power supply
« Reply #2 on: January 08, 2007, 07:55:29 pm »
Jay
If you want to use a 4 cell pack for the Rx supply, you need to wire it up to an Rx plug. It depends a bit on which make you have, but generally the servo connections are white or yellow for the signal, red for positive and black or brown for negative. You just need the red and black for the the supply.
You say you are using the main supply at the moment. I assume this means that you are using a BEC supply from the ESC. If this is the case, you must disconnect the RED wire in the ESC to Rx plug. A good way of doing this is to use a short extension lead and cut the red wire in that - means you can revert to BEC power if you want.
Hope this answers your questions.
Barrie
PS Terry got in before me, but the above may clarify things.
J.beazley
Re: Rx power supply
« Reply #3 on: January 08, 2007, 08:24:51 pm »
cheers shipmates, had a bit of memory lapse when i posted this thread.
found a 4 cell holder kicking around in the cupboard on problem is its got an "old" style connector and wont fit my reciever.
could i take the connector off my ESC and swap the plugs over??
how long would a 4.8v using 1000Mah cells last???
Jay
Re: Rx power supply
« Reply #4 on: January 08, 2007, 08:31:55 pm »
Jay,
Just bring it over
J.beazley
Re: Rx power supply
« Reply #5 on: January 08, 2007, 08:43:26 pm »
sorted. ;D ;D
cheers bob will pop over sometime in the week with the Schutze  ;) ;D
almost there just re-spraying the cannon and painting the hand rails again.
Jay
Re: Rx power supply
« Reply #6 on: January 08, 2007, 09:11:57 pm »
Hi Bob
Thought you told me not to bother.
Richard ;)
Page created in 0.081 seconds with 21 queries.
