Author Topic: enya 15 marine  (Read 1150 times)
gwa84
enya 15 marine
« on: May 26, 2010, 07:29:19 pm »
douse enbody know wher i can get a manual with the origanal settings for this engine please having some trouble getting it running thanks
Re: enya 15 marine
« Reply #1 on: May 26, 2010, 07:39:47 pm »
Hi there gwa84
Is it the Enya 15 IV if so, its a 2.4cc one - and according to the booklet I have you should be running a 9 x 3 prop:
From the instructions - ensure that the fuel tank is in such a position that the height of fuel surface is nearly equal to the height of carburetor.
Starting the engine: Close the needle valve fully; then open the needle valve 1 1/2 to 2 turns - inject several drops of fuel into the air intake and also the exhaust port.  Crank the engine 2 or 3 turns.   After the engine starts it will be necessary to adjust the needle valve to make it run smoothly.
If you PM me your address - I will scan the instructions I have and send you a copy of the 2 page booklet - although it doesnt say much more than I have quoted above.
hope that helps.
aye
john
