Author Topic: strange behavior  (Read 3733 times)
dazz
strange behavior
« on: January 10, 2007, 11:40:56 am »
hi,my father im law has a model boat,he was testing it today out of the water,he wanted to just run it for a few minuits so he pushed the trim slightly so as it would run un aided,he turned off the trans by mistake but the motors kept running at the same speed as they were set,why is this,what can he do to rectify it,thankyou in advance,daz  :-\
roycv
Re: strange behavior
« Reply #1 on: January 10, 2007, 12:50:08 pm »
Hi was this using a Bob's board speed controller?
Roy
barriew
« Reply #2 on: January 10, 2007, 04:07:43 pm »
That is not unusual. The correct procedure is rx on, tx on, rx off, tx off. If you don't follow this, then you can get the rudder moving and also the motors turning. You can't really stop this happening in a case like you describe. You have to stick to the sequence.
Why it happened some of our more technically competent members will probably explain ;D
Barrie
« Reply #3 on: January 10, 2007, 04:40:20 pm »
Barrie,
I think (hope) you meant:
 Tx  on,   Rx on,   Rx off,  Tx off
That way you are always in control of the boat.
Doug
Ghost in the shell
« Reply #4 on: January 11, 2007, 12:14:33 am »
dougal, thats what i thaught, so that when your model goes live, the signal is waiting for it, otherwise your model may fire up without warning
Go Nuclear!  you'll love it
« Reply #5 on: January 11, 2007, 08:14:05 am »
I had this with a mechanical speed controller. Cut the power on the tx and the controller stops in last position tx set it.
Richard ;)
roycv
« Reply #6 on: January 11, 2007, 11:42:18 am »
Hi all I agree Tx, on first, off last.
If the Tx is not on there is not the train of pulses which are amplified for the ESC.  Not sure about the high frequency units though.  This is a typical problem if a mechanical speed controller is used.
regards to all Roy
barriew
« Reply #7 on: January 11, 2007, 12:08:21 pm »
You of course correct - I really should learn to read my posts.  Apologies if I confused anyone.
Barrie
dazz
« Reply #8 on: January 12, 2007, 01:07:33 am »
thanks to you all for your time,i will pass on your replies,daz
Page created in 0.973 seconds with 17 queries.
