Author Topic: Lipo batteries  (Read 3363 times)
Ben Tickle
Lipo batteries
« on: June 01, 2010, 08:37:56 pm »
I was jsut wondering if anyone knows if the Jeti JES600 speed controller is capable of running lipo batteries??
Ben
Subculture
    • Dive-in to Model submarines
Re: Lipo batteries
« Reply #1 on: June 01, 2010, 08:41:51 pm »
You can use any speed controller with lipos providing you run the controller within it's specified voltage range.
I'd also recommend fitting a lipo guard so that you don' run your lipos beyond 3 volts per cell.
e.g. http://www.dimensionengineering.com/LipoShield.htm
Ben Tickle
Re: Lipo batteries
« Reply #2 on: June 02, 2010, 08:42:30 am »
Thanks for your advice. Another question, how do you charge them ie balance board??? And how do you solder the connector on?I didnt think lipos like heat
ben :}
Subculture
Re: Lipo batteries
« Reply #3 on: June 02, 2010, 09:01:08 am »
Solder them? Are they made up into a pack or have you purchased loose cells? If you have a pack with some flyleads attached, just solder on a connector like any other kind of battery pack. I use Deans connectors, which I find are excellent and very easy to fit.
You should balance lipos, and you must use a charger designed for charging this type of battery. Lipos are unforgiving in this respect.
Re: Lipo batteries
« Reply #4 on: June 02, 2010, 10:07:14 am »
Lipos do have a tendancy to go pop dramatically if abused
http://www.youtube.com/watch?v=z3o_2mwRPdw
Subculture
Re: Lipo batteries
« Reply #5 on: June 02, 2010, 12:51:43 pm »
So do most batteries. Use them within their specifications, use a correct charger, and keep the cells balanced and you should have no problems- been using li-pos for about seven years without complaint. Superb batteries
tt1
Re: Lipo batteries
« Reply #6 on: June 02, 2010, 05:52:22 pm »
Please excuse me for jumping in on the topic but a newbie having no experience of Lipo's and re Subculture's point, how do you balance the cells or keep them balanced?
               Cheers, Tony.
John Mk2
Re: Lipo batteries
« Reply #7 on: June 02, 2010, 07:07:32 pm »
Re: Lipo batteries
« Reply #8 on: June 03, 2010, 05:10:20 am »
Page created in 0.542 seconds with 17 queries.
