Author Topic: Flexi Shaft info needed  (Read 3875 times)
Drkomen86
« on: June 16, 2010, 11:47:53 am »
I bought this rudder and flexi shaft unit on ebay very cheap, all I need to know is what size of shaft I will need and what other parts are needed.
Im completely new to flexi shafts so all info and links are very welcome.
http://cgi.ebay.co.uk/72-115mm-CNC-RC-Boat-Ship-Helm-Rudder-Shaft-Holder-/110477131400?cmd=ViewItem&pt=UK_ToysGames_RadioControlled_JN&hash=item19b8f33e88
martno1fan
Re: Flexi Shaft info needed
« Reply #1 on: June 16, 2010, 12:02:57 pm »
You need a welded flex and stub setup,a collet to fit at the motor or engine ?to hold the flex only you know what length you need.Get longer and cut to length with a dremel cutoff wheel once you have everything else setup so you know how long you need it.They should be able to supply the flex or try Dave Marles he sells them.You can buy them with stuffing tubes also,you need to bend it to shape with the flex inside it so as not to kink it  ok2.What motor are you using,leccy or niitro? im asuming that rudder is for a 3/16" shaft ?.
http://stores.ebay.co.uk/PMB-rc-parts_FLEXISHAFTS-ALL_W0QQ_fsubZ902579013QQ_scZ1QQ_sidZ72990563QQ_sopZ10QQ_trksidZp4634Q2ec0Q2em322
Drkomen86
« Reply #2 on: June 16, 2010, 12:47:09 pm »
it is for an electric motor, so is the stuffing tube just a brass pipe??
not sure on the shaft size tbh, hav jst sent a message to ask  {:-{
Drkomen86
« Reply #3 on: June 16, 2010, 01:00:15 pm »
Also does anyone have any pics of a flexi shaft fitted, just to help me understand how it all works  :embarrassed:
colin-d
« Reply #4 on: June 16, 2010, 01:07:45 pm »
this any good..??
martno1fan
« Reply #5 on: June 16, 2010, 02:40:14 pm »
You can go with that setup above which will need soldering or you can get a round collet to hold the round flex at the motor end with a welded on stub shaft that just needs triming to length no soldering.Stuffing tube is thin walled brass tubing,they should have all you need if you ask or as i say try Dave at pmb.
Mart
pic of round colet
Drkomen86
« Reply #6 on: June 16, 2010, 09:15:07 pm »
there both amazing thanks  :-))
martno1fan
« Reply #7 on: June 16, 2010, 09:37:06 pm »
Heres a pic of the transom,not my boat took it off jonnys site ,also a good source for props and hardware etc.
Mart
http://stores.ebay.co.uk/Head-of-the-River-RC-specialist
