Author Topic: seawolf front planes mod  (Read 5072 times)
submate
« on: June 21, 2010, 08:01:27 pm »
I eventually got round to activate the front planes by installing a mini servo and going through the aft bulkhead with a ubend in the connecting rod and a magnet on the end.
This connects to a long rod directly that push/pulls the planes. I have a leveler on the rear planes.
I have trialed the sub and at first she dived and surfaced as it says on the tin but on the last sail I had problems, will report back when sorted.
Here are some pics for your purusal. ;D
submate
Re: seawolf front planes mod
« Reply #1 on: June 22, 2010, 03:24:49 pm »
Further to my last post, observations and any comments would be welcome :-))
xilsoe
« Reply #2 on: June 22, 2010, 04:17:13 pm »
I have been considering how to do the same on my sea wolf.
I think my approach would be to fix a servo inside to WTC and go through the front bulkhead. Then I would need to connect the servo to the receiver when I prepare the sub
submate
« Reply #3 on: June 22, 2010, 07:04:35 pm »
xilsoe
I find, the only problem with that, is you will have to find a way to connect the servo to the planes when you re-insert the tray into the
WTC?  :o
hollowhornbear
« Reply #4 on: June 22, 2010, 08:32:02 pm »
"o" ring either end, don't glue the front end cap on, fix the servo in the front end cap, then use a servo extension lead to connect to thr receiver. simples.
submate
« Reply #5 on: June 22, 2010, 09:03:11 pm »
hollowhornbear
This was my first model for a long time so ' I WAS ONLY OBAYING ORDERS' and fixed the front O ring.
Subsequently after joining Mayhem I have seen the error of my ways.
hollowhornbear
« Reply #6 on: June 22, 2010, 10:57:30 pm »
mmm not going to be so easy, then. what did you glue it with?
xilsoe
« Reply #7 on: June 23, 2010, 01:32:31 pm »
I would fix the servo in the WTC, not on the tray.
submate
« Reply #8 on: June 23, 2010, 04:53:40 pm »
I am sorry to say, epoxy equivalent to stabilt :o
submate
« Reply #9 on: June 23, 2010, 04:57:03 pm »
The servo is in the WTC on the equipment tray, sorry for any confusion :o
submate
« Reply #10 on: June 23, 2010, 04:59:21 pm »
hollowhornbear
I ment to say I fixed the front bulkhead not the O ring, what a wally! :((
« Reply #11 on: June 23, 2010, 06:32:42 pm »
This is how I did mine.
 The planes were on a spring return.....
