Hi there.
@ 52 inches It is the veron kit you have as I have one my self, it is sold as the trinidad and tobago coast guard ship
HMTS Courland Bay. The malaysian navy also had it. There is a funnel abaft the supestructure on the model, the ferocity has
none.
The Perkasa is the commercialy sold vessel from the Ferocity design with the 4 fish, twin bofors, and similar style cabin and
tapering aft suprtstructure. Thay were sold to Germany, Denmark, Malaysia, Libya, and Brunei navies.
Fleetscale do a semi-kit with fittings for your model, there are some photos of the finished model as well, theirs is sold as the
HMTS Trinity.
I had an idea for a rotating gun which should work on paper...as they ofcourse they do but you could try it.
1. attach a piece of rod metal, wood, whatever material you choose, or what I would call fix a pin to the base of the gun so
that it goes through a hole in the deck.
2. Attach a cross shaped servo horn to the bottom of the pin. Two of the arms should be parallel with the base of the gun, the
barrel pointing forward.
3. attach a clevis rod to the servo horn at the gun end and a servo to the other end of the clevis rod.
4. The systen I an describing is the same set up as you have on the rudder. servo pushes the clevis rod- pushes the tiller arm-
turns the rudder..why not a gun its just the same rotary movement.
Hope you get the idea?
.. ........................cheers Frank..
