Model Slipway RTTLhttp://www.modelslipway.com/Vosper%20RTTL/Vosper%20RTTL.htmKit Contents: Running gear including motor, prop-shaft, propeller, rubber coupling, tiller arm. Thermo-formed styrene hull / deck / one-piece cabin / internal tray with motor mount, battery tray / rudder halves / windbreak / winch-house / dinghy. Also provided are printed plastic parts, clear glazing, a set of metal fittings; wire for railings, ABS tubing for mast. Vinyl lettering for RTTL No. 2751 to 2755, and roundels. Step-by-step assembly drawings, instructions and plan of the highest standard. Kit for model makers with a little experience.
Additional items required to complete the model:
▪ Tools: a good pair of scissors; a modelling knife; fine sandpaper; a sanding block; small round and flat files; pliers.
▪ Adhesives: a tube of polystyrene cement, liquid polystyrene glue, thick cyanoacrylate (Superglue), R/C Modellers Craft Glue or Flair Canopy Glue, or Weldbond (for window glazing). Humbrol plastic filler.
▪ Paints: Humbrol enamels or Tamiya; alternatively Halford's acrylic aerosols.
▪ R/C requirements: 2-channel radio, Mtronik Viper Marine 15 electronic speed controller. 1x battery pack: 6x AA cells 2700 mAh NiMH (7.2 volts) and charger.
