Pages: [1] 2 3 4 5   Go Down
Author Topic: PT Boat build  (Read 53010 times)
AndrewB
PT Boat build
« on: July 16, 2010, 11:24:25 am »
Well I have the ply and have made a start with the ribs :-) these are made out of 3mm marine ply
I am waiting for the builder who has been renting our garage to move on so I can set up, I have been working in the lounge at the moment, not ideal.
AndrewB
Re: PT Boat build
« Reply #1 on: July 29, 2010, 10:52:47 am »
I have been doing a bit of work as i have the time, sanding, cutting. So this is the boat with the ribs just sitting on the building runners.
freelance 1
Re: PT Boat build
« Reply #2 on: August 04, 2010, 08:01:11 pm »
Andrewb..... which pt boat are you building.??
pat
AndrewB
Re: PT Boat build
« Reply #3 on: August 05, 2010, 12:42:31 am »
pat
Hi Pat
Free drawings were from http://www.pt-boat.com/ Quite good. It is a 1:20 of the Elco 80'
Andrew
AndrewB
Re: PT Boat build
« Reply #4 on: August 06, 2010, 11:32:57 pm »
Hello all
Well I have just put my order in with Dave at ACTion Electronics, this is what Dave suggested and is what i have ordered   http://www.action-electronics.co.uk/pdfs/HMS%20Brave%20Borderer%20MTB%20-%20Nick%20Panter.pdf
I cant wait for it to turn up.
Thanks to Dave, a great help  ;)
AndrewB
Re: PT Boat build
« Reply #5 on: August 13, 2010, 11:05:37 pm »
Hi all
I have just received my controller bits from ACTion electronics, great service and the product looks well made.
AndrewB
Re: PT Boat build
« Reply #6 on: August 24, 2010, 08:21:26 am »
Ok the latest on my wee project, I have the sanded the frames set up and glued onto the build runners, It is looking quite good, I am please so far.
AndrewB
Re: PT Boat build
« Reply #7 on: August 30, 2010, 08:25:35 am »
Ok the weather has been rubbish here in Wellington,  have a look at my weather site www.brooklynweather.co.nz
 Not that I need an excuse to work on the boat, I took the opportunity, I made up and fitted the outer keels for the outer prop shafts
jonny shoreboy
Re: PT Boat build
« Reply #8 on: August 30, 2010, 12:20:51 pm »
Hi mate, looking good so far. How big is this beasty going to be once it's finished? As for the weather in Windy Wellington, well landing there in a plane is an experience in itself! The wife and i will be driving through there in January.
AndrewB
Re: PT Boat build
« Reply #9 on: August 30, 2010, 08:16:38 pm »
Hi Jonny
the beasty is 1200 mm long, as for flying in to Wellington in a decent southerly, its a experience not to be missed  ;)
AndrewB
Re: PT Boat build
« Reply #10 on: September 02, 2010, 10:02:09 am »
Hi All
Well it's been a bit quiet on the PT front, just a bit of sanding at nights. But I had some bit turn up from J R Haynes yesterday that I have made up, pretty good stuff too.
Gra
Re: PT Boat build
« Reply #11 on: September 02, 2010, 10:29:41 am »
Hi Andrewb,
Your second photo showing the 20mm Oerlikon appears to be mounted incorrectly.
The barrel mounting should be the other way around.
Not being smart just trying to help.I have a 80ft and 77 ft Elco at 1/24 scale.
I have used the J/Haynres armament on my 80ft Elco.
Gra
AndrewB
Re: PT Boat build
« Reply #12 on: September 02, 2010, 10:58:12 am »
Hi Andrewb,
Gra
Good spotting, Thanks for that
AndrewB
Re: PT Boat build
« Reply #13 on: September 08, 2010, 10:31:53 am »
Well I have started the hull planking, I am finding it quite relaxing  :D
AndrewB
Re: PT Boat build
« Reply #14 on: September 11, 2010, 08:06:38 am »
jonny shoreboy
Re: PT Boat build
« Reply #15 on: September 11, 2010, 11:03:27 am »
Looking really good mate. The planking looks really neat and tidy!
Re: PT Boat build
« Reply #16 on: September 11, 2010, 03:58:54 pm »
Hi there ~Andrew B ~ nice looking build and I like the way you have assembled the frames on the building board.
I have a couple of queries - I wonder why you havent added intermediate stringers on the bottom and the side?   Because, adding these helps you get the correct flare at the bow on the bottom and on the sides.
Also, why have you planked one side first completely?  Because normally, planking one side at a time like this you may distort the hull sometimes.
So put a straight edge along your keel just to check.
As the glue dries out which is securing the planks, it tends to shrink and the plank tends to move and this can cause some distortion.
Lastly, are you going to double diagonal plank your hull?
Looking really good.
aye
john e
bluebird
Martin13
Re: PT Boat build
« Reply #17 on: September 11, 2010, 09:46:46 pm »
G'Day Andrew,
A great looking hull and good planking job to boot. I also concur with Bluebird re intermediate stringers - I built a 6 foot Brave class hull and later wished I added more stringers as this would have aided in obtaining the correct profile a lot, lot easier.  O0
But having said that, it's great to see another plank on frame hull on this side of the globe and yes, planking is fun :-))
Martin doon under
AndrewB
Re: PT Boat build
« Reply #18 on: September 11, 2010, 10:29:26 pm »
G'Day Andrew,
Martin doon under
Hi Martin and Bluebird
Thanks for that guys
The stringers a bit embarrassing, as I have the wood to put them in, but I got a wee bit ahead of myself and forgot  :embarrassed:
Anyway, I'm quite please with the out come so far, I was i bit worried when Bluebird mentioned the hull distorting, but I seem to have got away with it :-))
in saying that I have used Wurth Cyano (I get it cheep as I am a rep for them) on the first layer, the second layer will be a good quality wood glue. Any suggestions would be great..
Thanks for looking
AndrewB
Re: PT Boat build
« Reply #19 on: September 19, 2010, 08:11:29 am »
Ok, all the first layer of planking has been completed, onto the second layer now, the stunning thing is , I still am finding it relaxing  ;)
leggolon
Re: PT Boat build
« Reply #20 on: September 20, 2010, 05:13:31 am »
Very nice! Beautiful planking work.  I will be following your building thread...........................................Larry G.
AndrewB
Re: PT Boat build
« Reply #21 on: October 02, 2010, 01:02:20 am »
Well planking is done!
And one to show the view
Re: PT Boat build
« Reply #22 on: October 02, 2010, 01:48:47 am »
..... %% Andrew says..... "Well planking is done!"
A bit difficult to get our KIWI cousins to get their story straight.....as my take on this is ........the planking has been VERY well done  :-))
Woking with real wood is such a rewarding process...... :} ....Derek
AndrewB
Re: PT Boat build
« Reply #23 on: October 02, 2010, 05:45:08 am »
Cheers for the correction Derek :-)
Re: PT Boat build
« Reply #24 on: October 02, 2010, 06:06:41 am »
 :o  Andrew....is "woking" a KIWI word or did I make it up?  {-) {-)  %) sorry......  %%
Please post many snaps as your project progresses....Mayhem members love to see the build O0 ,,,,,,,,,,  Derek
Pages: [1] 2 3 4 5   Go Up
Page created in 0.03 seconds with 22 queries.
