Author Topic: Aeronaut Torben  (Read 6300 times)
Haarek
Aeronaut Torben
« on: July 18, 2010, 10:28:32 pm »
Hi all mayhemers,  this is my first build on mayhem and it`s the Aeronaut Torben.
The boat is 73cm long and 23cm wide, it`s powered by a Robbe 755/40 12v motor and a 12v 7,2Ah sla battery.
This is how far i have come in a couple of days work.
Haarek
Re: Aeronaut Torben
« Reply #1 on: July 21, 2010, 10:50:44 pm »
Got some more work done on Torben today.
The kit is very easy too put together and is a perfect beginner boat.
I cut out some of the parts for the wheelhouse, it was a very easy job but the plastic in this kit is badly warped so it needs a bit of work too get it straight.
Any bright ideas on how to fasten the superstructure too the boat as the tow hook is on the superstructure and i`m going too use it for towing.
Tug_Fan
Re: Aeronaut Torben
« Reply #2 on: August 11, 2010, 04:17:26 pm »
Hello Haarek,
this boat looks really nice! :D
Please show us more pictures!
Best Regards to Norway
Holger
Darklord
Re: Aeronaut Torben
« Reply #3 on: April 14, 2011, 11:02:04 pm »
Hello Haarek,
How did you get on with this build? Did you finish it?
I am just about to start to build a Torben myself and I don't see many of them about.  <:(
gregk9
    • Chasewater Model Boat Club
Re: Aeronaut Torben
« Reply #4 on: April 15, 2011, 12:15:26 am »
As a simple solution to hold the superstructure down for towing try this.
if you source a long nut and bolt that will reach from a convenient point on a flat part of the superstructure, to just below deck level. Affix a suitable piece of square section wood dowel across under the deck, with the nut secured to the under side of the cross bar, then you can drop the bolt down through the superstructure and merely tighten with your fingers, this will be sufficient to hold it all down and prevent it from pulling off under a tow. Dotn try ightening the bolt down with a spanner, just incase you need to access inside the hull quickly in an emergency.
You can always hide the head of the bolt with a small cabinet or locker, so it does not stand out too much.
or if you cant find a bolt long enough, then buy a piece of threaded rod and cut a length to suit your requirements.
best of luck with the build, its looking great.
Best wishes.
Steve. G.
Treasurer & Membership Secretary:  Chasewater Model Boat Club
http://chasewatermbc.blogspot.com/
fletch62
Re: Aeronaut Torben
« Reply #5 on: January 08, 2012, 09:39:08 am »
hi haarek have you any more pictures of the boat as ive just got my self the same kit and would like to see how you are getting on with yours thans brian
tugmad
Re: Aeronaut Torben
« Reply #6 on: January 08, 2012, 10:35:30 am »
Hello Haarek  The Torben is a lovely little boat I built one for my Grandson some 12 years ago and he has now grown out of model boat unfortunayely so I gave it a makeover and altered her a little. but as you see from the picture she tows very well , the superstructure by the way is a good fit to the coaming,and I do not fix it in any way, BUT I always use a stop rope so that the pull on the hook is from astern all the time, looking forward to seeing pictures of her on the water,all the best  george.
Re: Aeronaut Torben
« Reply #7 on: January 08, 2012, 11:36:58 am »
Very impressive Geo.   :-))
tugmad
Re: Aeronaut Torben
« Reply #8 on: January 08, 2012, 01:28:40 pm »
thanks Ken   another picture added
tugnut
Re: Aeronaut Torben
« Reply #9 on: January 08, 2012, 02:36:31 pm »
Hi Haarek thats a neet build she is a great Tug, as george said towes well.
Thats a good pict geo.
Re: Aeronaut Torben
« Reply #10 on: January 08, 2012, 03:02:15 pm »
Excellent photo!
Page created in 0.099 seconds with 22 queries.
