Author Topic: Decking thickness, underdeck & planking  (Read 2723 times)
a3nige
« on: July 27, 2010, 08:45:24 pm »
Somewhere I have read about putting deck planking for a yacht on a sheet of plywood, can anyone tell me what thickness the ply and the planking should be? The yacht is a 2 metre 'A' class that I want to turn into something scale, possibly like a 'J' class (although I am open to suggestions) also, how do you finish off the edge of the deck against the hull.
Thanks,
Nige
"You're a hard person to ignore, but well worth the effort !"
Prophet
Re: Decking thickness, underdeck & planking
« Reply #1 on: July 28, 2010, 10:07:48 am »
try a 2-3mm ply base then use planking material from here.
http://www.alwayshobbies.com/Boats/Materials/Planking-and-Mouldings/Planking-Stripwood.ice
Planking is usualy 1mm thickness
Lime works better because it flex's to the contors better but its your choice.
To get the black lines between the planks on the base of each plant ( bottom side/glue side) run a black marker along the edge.
for a thin line only black mark one plank and butt to a clean plank..
for a thick black line mark both edges to butt together.
To finish the edge of the deck off use 1/4" obeche strips shaped and stained
Hope it helps  :-))
a3nige
« Reply #2 on: July 28, 2010, 11:51:49 am »
Thanks Prophet,
Nige
