Model Boat Mayhem - Forum
Author Topic: HELP!! Kyosho Dolphin outboard shaft broken  (Read 3990 times)
RobinC
« on: August 02, 2010, 05:17:08 PM »
I've put this in the main boating forum but have added here as I'm desparate! As a newbie I have just completed hours of work building a Kyosho Wavemaster catamaran to replicate my (full size) race boat. First shake down with the standard motor it snapped the flexi shaft, and I hav'nt even fitted the brushless w/c motor yet! Now I discover they are obsolete, local shop was no help and I can't find anything on the web. The shaft is a flexi, 120mm long x 3.2mm with 2.5mm squares at each end. Other than buy a complete Groupner unit I'm at a loss as to what to do to stop it turning into a static. Any help would be much appreciated to save an old retired racer from despair.
Robin
Prophet
Re: HELP!! Kyosho Dolphin outboard shaft broken
« Reply #1 on: August 02, 2010, 05:43:49 PM »
Have you got a pic of the part and the boat? might be able to convert it to a ridged shaft if you cant find the right size flexi shaft.. try google searching for flexi shafts there are tons on the market!
TRY HERE
http://www.modelboatbits.com/index.php?p=1_22
HERE
http://www.astecmodels.co.uk/catalog/catalog_products_with_images.php?listing=manufacturers&page=17
HERE if your in the usa
http://www.funrcboats.com/ProductInfo.aspx?productid=FDHUE1077
HERE (3364 Flexible Shaft with Teflon Tube 190mm) its 3.2mm by 19omm)
http://www.cornwallmodelboats.co.uk/acatalog/graupner_propshafts.html
Martin [Admin]
« Reply #2 on: August 02, 2010, 05:57:06 PM »
RobinC
« Reply #3 on: August 02, 2010, 06:53:07 PM »
Thanks guys,
I don't really want to convert to rigid shaft, I prefer to keep it as a true outboard. I can find a longer 3.2 dia shaft I could cut to length but then have the problem of making the end at the output shaft square to fit the shaft, at the motor end I can leave it round and use a coupler so thats not so much of a problem. Looking on the web this does appear to be a perrenial problem.
Robin
Prophet
« Reply #4 on: August 02, 2010, 07:17:56 PM »
file the end take about 20 mins.. job done
RobinC
« Reply #5 on: August 02, 2010, 07:30:38 PM »
I was thinking that, but it seemed a bit of a bodge, if I solder tin the end and then file it will it maintain the strength as it will take away the wire thickness? The originals look like they have been pressed.
Could try tinning and pressing in a vice with smooth jaws? Any one done this?
I was hoping I was going to get someone who had the same unit and had an easy way. Nothings easy in life!
Robin
hmsantrim
« Reply #6 on: August 02, 2010, 09:39:24 PM »
Hi Robin.
              Is this it here
        http://www.tamiya-store.com/shop/flex-cable-stub-shaft-for-small-dolphin220mm-p-90019206.html
           product added to our catalogue May 2010    $8.00
                                      cheers Frank
RobinC
« Reply #7 on: August 02, 2010, 10:06:29 PM »
Frank
I don't think so, yours is 220mm long, the one I need is 120mm, there is no mention of the dia so it may be 3.2 and able to be cut of to length. The correct one is Kyosho part no K94631-3, can you still get those as spares in the states?
Robin
hmsantrim
« Reply #8 on: August 03, 2010, 03:54:32 AM »
Hi Robin.
          Re:  can you still get those as spares in the states?  Dunno matey I`m oop North..
          but we can go  2 plan B
         http://www.castyouranchorhobby.com/item--Dolphin-II-Outboard-Motor--81505
http://www.drcwebservices.com/ffe/hardware.htm    3.5 shaft don`t say length?
K94631-3,  http://www.hopupplanet.com/shopcart.asp?pg=products&specific=jmnorrgonoo4 .... dam it
                http://shopkyosho.com/products/productdetail/DOLPHIN+OUTOBOAD+MOTOR+II/part_number=94771/410.0.1.1.25387.25418.0.0.0
http://www.boatracingfacts.com/forums/showthread.php?p=86020
                a forum there you can join and ask them   some other sites to look at may find something
                     thats all the info there is
                                     cheers frank
RobinC
« Reply #9 on: August 03, 2010, 09:53:38 AM »
Thanks Frank
Thats great, I have emails winging everywhere, see what comes up. The Kyosho site shows the shafts listed and in stock, BUT, when I tried to buy 5 of them, they don't supply outside of the USA!! Come on guys there is life outside!
Don't suppose there is an American on this site who would buy them and ship to me?
Robin
