Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14]   Go Down
Author Topic: Battleship Bismarck - 1:100  (Read 141271 times)
Tomasz.
Re: Battleship Bismarck - 1:100
« Reply #325 on: April 17, 2023, 05:50:19 pm »
work on catapults
Tomasz.
« Reply #326 on: April 29, 2023, 07:07:36 pm »
painted with primer paint
littoralcombat
« Reply #327 on: April 30, 2023, 12:33:16 am »
Very, very impressive Tomasz, the detail is at a whole new level.
I really enjoy looking at your work, it demonstrates what is possible.
I couldn't agree more.
Tomasz, your work is truly inspirational, thanks for sharing your progress.
Nigel
Tworrs
« Reply #328 on: May 01, 2023, 10:36:50 am »
Tomasz, thank you for sharing your progress once again, it is really appreciated.
Garry
Tomasz.
« Reply #329 on: May 04, 2023, 06:15:13 pm »
Another cutter, Motorbarkasse 9.2m, is being built.
Tomasz.
« Reply #330 on: June 07, 2023, 02:22:22 pm »
rowing boats
Tomasz.
« Reply #331 on: June 07, 2023, 02:23:18 pm »
next photos
Tomasz.
« Reply #332 on: June 09, 2023, 05:05:25 pm »
last piece of the aft superstructure completed
Dreadnought
« Reply #333 on: June 10, 2023, 01:23:13 pm »
Looks Good!  :-)) :-))
raflaunches
  • The Penguins are coming!!!
« Reply #334 on: June 10, 2023, 09:31:14 pm »
Proper job, got to be the best model of Bismarck out there  :-))
Nick B
Illegitimi non carborundum!
Beagle1831
« Reply #335 on: June 10, 2023, 10:28:13 pm »
I agree with Nick!
Superb model - amazing.
Work in progress and RN history on Instagram @beagleshipmodels
Tomasz.
« Reply #336 on: June 14, 2023, 06:11:16 pm »
Beagle1831
« Reply #337 on: June 14, 2023, 06:21:19 pm »
Brilliant! :-))
Geoff
« Reply #338 on: June 15, 2023, 03:25:28 pm »
As always superb workmanship. One way to make oars is to use styrene rod and simply squeeze flat in a smooth jaw vice. Too much and it looks like a paddle but its easy to do and very quick and takes about 3 seconds to make an oar.
In theory this should work with aluminium or even copper assuming you can get enough pressure.
Geoff
Tomasz.
« Reply #339 on: June 15, 2023, 04:54:03 pm »
certainly dozens of paddles made with this technique will not come out identical
« Reply #340 on: June 15, 2023, 06:07:29 pm »
I have had success with taking a light hammer to brass wire to make miniature oars and trimming each end to make them equal.
Tomasz.
« Reply #341 on: June 21, 2023, 05:38:18 pm »
hangars, motor boats, lifeboats and funnel in common photos :D
cos918
« Reply #342 on: June 21, 2023, 05:40:19 pm »
Look fantastic. I have never seen so much detail .
Geoff
« Reply #343 on: June 22, 2023, 12:31:19 pm »
[/size]
[/size]
[/size]In fact they do, its only a question of noting how far you push the vice lever, the rod material is entirely consistent so the "squash" factor being the same produces identical oars. Not tried it with metal but the process should be the same.
[/size]Cheers
[/size]Geoff
Tomasz.
« Reply #344 on: July 07, 2023, 11:14:12 am »
Both superstructures assembled for photo although not yet glued.
« Reply #345 on: December 03, 2023, 11:48:23 pm »
That bridge would win awards in any modelling show anywhere on its own Tomasz!
Amazing work.
littoralcombat
« Reply #346 on: December 11, 2023, 07:44:07 pm »
Tomasz, your work is truly inspirational.
Thanks for continuing to share your progress, I always look forward to your updates.
Nigel
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14]   Go Up
Page created in 0.034 seconds with 21 queries.
