Author Topic: Setting of prop in Korts nozzle.  (Read 9188 times)
Bluechrisp
« on: August 07, 2010, 01:40:47 pm »
Afternoon all,
I'm just setting my prop into the nozzle, my thinking is the back of the prop should be lined up with the back of the nozzle, is that the same view, my fellow tuggers have..?   %)
My home made nozzle copper tube is 50mm ( mouth ) wide by 40mm long. :D
Chris P
Re: Setting of prop in Korts nozzle.
« Reply #1 on: August 07, 2010, 02:27:39 pm »
Thats the way I've done mine Chris.
See your location is sometimes Blairgowrie, used to go there quite a lot when I drove for Christian Salvesen.
Bluechrisp
« Reply #2 on: August 07, 2010, 03:05:54 pm »
Hi Dicky,
Thank you for that, just seeing how the mighty all knowing forum had to say....  :-)
Ahh yes sunny blairgowrie, have family up there, me and the kids use Davey park sometimes, alittle run down... not a true boating pond but ldeal, outside of the weed season. Were you transporting the fruit or wood? Going back up soon for the forth time this year.....  :-))
cheers
Chris P
« Reply #3 on: August 07, 2010, 04:32:40 pm »
I was going back a bit, it was frozen food and fresh meat we were carrying back then.
« Reply #4 on: August 07, 2010, 04:46:14 pm »
Salvos in Grimsby Now Norberts!
« Reply #5 on: August 07, 2010, 05:02:05 pm »
Used to be a good firm to work for when I was there Ned, it used to be the largest storer and shipper of frozen food in Europe. Mercedes used to design trucks specially for us. All gone to pot now thanks to the money men.
ministeve
  • washing the decks!!!
« Reply #6 on: August 07, 2010, 05:44:25 pm »
i always set the centre of the prop (mid way from front face and back face) with the rudder post they steer very well going astern then. rudder post about 1/3rd back from front face of Kort if it will be a steerable Kort
works for me as some may know
Steve
toesupwa
  • USA'd ex Brit
« Reply #7 on: August 07, 2010, 06:27:43 pm »
To be the most efficient in forwards and reverse, the prop blades should be 1/3rd in to the kort from the front face.
It takes quite a bit of setting up to get a steerable kort to clear the prop blades though, especially if the tips of the blades are a close running fit in the kort.
Bluechrisp
« Reply #8 on: August 08, 2010, 11:08:46 am »
Hello Toes,
Hows wee Scoot these days, seen anymore action since portsmouth...?  :police:
I have a cm of shaft left to play with, so I'll see how it goes on the trials.  %%
CP
andywright
« Reply #9 on: September 01, 2010, 02:35:10 pm »
I make a circle of thin ply to fit in the nozzle, drill a hole in the centre, slide this over the shaft, then the prop needs to be about a third of the way from the forward end of the kort as spoken about earlier in this post. I tend to fix my nozzles first, then fit the rudder shaft with clearance for the nozzle to turn, the shaft can be held in place with blue tack to check, and then resin used for the final fix.
Bluechrisp
« Reply #10 on: September 15, 2010, 10:59:54 pm »
Thats a grand idea, I'll try that on my next tug. Thanks   :-))
allanb131
« Reply #11 on: September 16, 2010, 10:32:14 am »
Thanks for the tip. I am busy with fitting my Kort which I made from some plumbing today and was just sitting here trying to work out positioning.
Regards, Allan.
nemesis
« Reply #12 on: September 19, 2010, 10:19:49 pm »
Hello, when setting a prop in a kort nozzle, the centre line through the prop should be the centreline of the
rudder shaft, that is assuming that the prop in question is made for a Kort with the correct blade profile.
                                     nemesis
Bluechrisp
« Reply #13 on: September 22, 2010, 08:27:54 pm »
                                     nemesis
Hi Nemesis
It got a 45mm in a 50 home made set up, the 50 mm korts got thrown off second time on the Boating pond.  %) Looking to put all the good advice into another larger tug some when in the future.  O0
CP
mersey dave
« Reply #14 on: October 03, 2010, 10:52:22 am »
has anyone got any photo's of the set up, i am about to have a go at making one for the first time and in need of a bit of help when it comes to lining everything up.
Regards Dave.
MilanS
« Reply #15 on: October 27, 2010, 12:15:41 pm »
Last year I was made semiscale pushboat from Vltava river, with steerable kort
and here is kort design
Perhaps it can help.
MilanS
« Reply #16 on: October 27, 2010, 12:28:41 pm »
Ooops a wrong size. Second attempt.
octo
« Reply #17 on: October 27, 2010, 02:32:18 pm »
Excellent diagram, :-)) Love the pusher, :-)) can we see more please, Tony
MilanS
« Reply #18 on: October 27, 2010, 03:55:50 pm »
I do not know if it is right to give here, but some pictures from shipbuilding are
ttp://www.mo-na-ko.net/php/portal/gallery.php?akce=obrazek_ukaz&media_id=501
Complete drawings in Acad are too large.
Page created in 0.528 seconds with 21 queries.
