Author Topic: How different are red and black universal joints?  (Read 6449 times)
RockDam
« on: August 09, 2010, 01:13:07 pm »
I found many online shops in UK selling  red and black(Raboesch) universal joint.
How different are they ?
Peter
Re: How different are red and black universal joints?
« Reply #1 on: August 09, 2010, 01:54:19 pm »
The black couplings are by Dyco.
The splines on the couplings and brass inserts are different between the two manufacturers, and are not interchangeable.
Peter
« Reply #2 on: August 09, 2010, 01:59:44 pm »
The black ones are supposed to be better balanced, whilst the shaft holes in the red ones can sometimes be slightly off centre.
RockDam
« Reply #3 on: August 10, 2010, 01:13:19 am »
Thank you.
Hi Peter,
the google results for "Dyco Coupling" are red.
No problem, I will buy black.
Peter
« Reply #4 on: August 10, 2010, 04:40:17 am »
Hi
I have only ever used Dyco, from my local modelshop, and they have always been the black ones.
But from having seen the Raboesch red version, I have found that the parts are not 'easily' interchangeable. This was because of the spline difference on the joint and brass insert peices. I say 'easily', as they can be 'persuaded' to fit, but the end result may not run smoothly, without vibration.
Having also tried some 'Googling', everything now seems to be red.
Sorry I can't add anything more specific.
Peter
Arrow5
« Reply #5 on: August 10, 2010, 10:05:22 am »
Dyco are the red ones. O0
..well can you land on this?
Watchleader
« Reply #6 on: August 10, 2010, 10:27:41 am »
Don't get either! ok2
Just get the inserts to suit your motor and your prop shaft and cut a length of flexible gas pipe to push on them.  :-)) :-))
Works a treat and you can cut slightly varying lengths to suit your installation!!
Used this method on fast planing boats (see avatar) and is used on good sized tugs.  O0 O0
rathikrishna
« Reply #7 on: October 20, 2010, 06:42:55 am »
Good morning respected members..i have a little doubt about couplings. i will be a free bird as i resign my job to be a full time model maker. so i need ample of various couplings for my need..i saw two of here. but its far beyond my reach, as all you are in UK and US.in India no one is able to supply like one.so i have ordered some here in my lathe. so one doubt which metal is apropriate to make couplings..? MS or SS or Brass..? now i am coupling all shafts with ball point refill tubes coated with epoxy adhesives.not reliable much..please guide me once..
Watchleader
« Reply #8 on: November 03, 2010, 03:04:25 pm »
Hi Rathikrishna.
Make the end fittings from brass. Much easier to machine.
Use flexible gas pipe (as mentioned in earlier post) to join these.
Either use a cross pin, or glue or even just a push fit if the required torque is not too high.
Bob_V
    • Luton & District Model Boat Club
« Reply #9 on: November 03, 2010, 07:45:23 pm »
What are the dimensions and where can I buy Flexible Gas Pipe?
Bob.
Bob Vaughan
Arrow5
« Reply #10 on: November 03, 2010, 09:28:21 pm »
Aircraft model shop, ask for silicon exhaust tubing, dia to be push-fit over splines. You still need to get propshaft and motor shaft lined-up.
Watchleader
« Reply #11 on: November 04, 2010, 12:41:56 pm »
Hi Bob V
Look in local yellow pages for "Calor". The local supplier will have it readily available, at couple of pound a metre,
As arrow says - Silicon exhaust tubing is fine, although it is a little softer and costlier (but for the amount you'll use probably not an issue) :}
Bob_V
« Reply #12 on: November 04, 2010, 03:35:47 pm »
Thanks for the info. Will try and get some to try.
Bob.
Bob Vaughan
rathikrishna
« Reply #13 on: November 05, 2010, 01:16:10 pm »
Nice..and thank you for the knowhow..and by this time i have turned two from brass, and equiped with allen key bolt to tight the shaft..but when motor pumps up the full power the shaft is slipping inside the coupler and grinds off..so i have to try the exhaust tube mentioned above..thank you all...
« Reply #14 on: November 05, 2010, 02:06:20 pm »
Put a flat on the shaft where the Allen screw clamps to it??
portside II
  • tugs at rest
« Reply #15 on: November 05, 2010, 10:56:04 pm »
i try to make all my own cuplings now as it's realy cheap  O0
firstly the ends are made from brass rod , this is obtained from the carboot sales etc from companion sets (the things put by the fireplace with a poker brush etc).
secondly the flexable joint is fuel line (petrol) bought from your local motor factors , halfords etc.
Turn the brass so its a tight fit on the tube drill it out for your motor shaft / prop shaft (this might want a thread tapping out)
and then if its for a high torque application drill a 1mm hole through the rube and the coupling to take a wire retainer to stop it slipping.
I have used this method since i bought my lathe and it works out about 50p for the set up , depending  on how much i paid for the brass, the last set was free  :-)) .
daz
« Reply #16 on: November 06, 2010, 11:41:31 am »
Just spotted the error of my interpretation, the brass is spinning inside the flexible??
 Before the advent of plastic everything more than fifty years ago, we found pretty quickly that the plastic hose connecting the propshaft to an ED Racer didn't work. Most times it ground out the inside if the flexible and on one occasion broke the propshaft.
  Might be a noise thing or forgotton methods but the old "Rip-Max" universal ball joint coupler and the pin and disc, with varying media for the disc, have dropped into obscurity.
Page created in 0.296 seconds with 17 queries.
