Author Topic: Air Compressor  (Read 5097 times)
UKJonathan
Air Compressor
« on: August 17, 2010, 10:13:06 am »
Hi can anyone please tell what type of compressor I need to power small engines?
Jonathan
boatmadman
Re: Air Compressor
« Reply #1 on: August 17, 2010, 10:32:35 am »
It would be helpful if you could tell us how many and what type of engines you want to power. Also, is it for display or for driving something.
As a starter, I recently bought an Aldi 25l compressor for £80 to run in my steam engines. With the engine running at 20psi the compressor runs almost constantly to maintain  bottle pressure.
Bunkerbarge
Re: Air Compressor
« Reply #2 on: August 17, 2010, 01:05:32 pm »
As usual the biggest consideration is how much you want to spend.  I would definately recommend a reservoir type and be careful of some smaller compressors that are limited to running times.  A basic compressor with a small reservoir can be quite reasonable but a bit noisy so can be a problem for a hobby unit.  I bought a Clarke Shhh! model with a 9 litre tank which was on the expensive side at 250 pounds but it is based around a refrigerator compressor so very quiet and unobtrusive.
UKJonathan
Re: Air Compressor
« Reply #3 on: August 17, 2010, 01:47:45 pm »
hi thanks for reply's I'm just looking for something quiet for home use to run the odd little single cylinder engine
jonathan
Bunkerbarge
Re: Air Compressor
« Reply #4 on: August 17, 2010, 03:41:15 pm »
If it is only for short time running I would just get hold of an airbrush compressor, that should be about your cheapest option.  Apart from blowing up an inner tube with a foot pump that is!!
livesteam
how to connect?
« Reply #5 on: December 05, 2010, 04:19:11 pm »
Hi
I don't have any experiences with running an engine on compressed air. But now I would like to do so, to make adjustings at my TVR1A without burning my fingers... So I intend to use a Small aribrush-compressor, but how would you connect it with the steam inlet?
Thanks!
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
Re: Air Compressor
« Reply #6 on: December 05, 2010, 05:53:41 pm »
What's the connection on the end of the compressor hose?
Greg
Re: Air Compressor
« Reply #7 on: December 05, 2010, 06:06:24 pm »
Metal (Usually) - Screw on.
livesteam
Re: Air Compressor
« Reply #8 on: December 05, 2010, 06:31:56 pm »
Greg
As I don't have any compressor yet, I don't know... Thought I should think about it before I buy one.
KBIO
Re: Air Compressor
« Reply #9 on: December 05, 2010, 08:11:33 pm »
Good evening! :-)
One idea =
If you have a workshop,a garage or another place (but the bathroom)  {-) you can store one, you probably can buy a 50 liters , single cylinder compressor for 80£ (100€). Chinese stuff but reliable enough for the kind of work you will ask it.
It comes with hose and connections + some different spare connections in the box.
There is also a regualtor which allows you to adjust the pressure you want.
Myself, I use a plastic clear hose to connect on my engine, and do the break in (1 to 2 bars) , adjustments, or what ever I want.
It allow me to blow the water away after use, blow it dry and inject some oil before storage. Rising the pressure to 7 bars (100psi), I blow dust ,mist &  dirt away from the boat.
I also use it for spray paint,inflate kids's summer toys and other ..................and clean my mess on the bench! O0
It is stored underneath the bench for years and I do not see any reason to change it! %)
Santa is coming soon and if you have been nice, maybe , he will bring one to you! %)......
Regards! ok2
MOG8
Re: Air Compressor
« Reply #10 on: December 08, 2010, 11:56:18 pm »
I use an old fridge compressor.
It runs all my engines, except the Stuart N°1.
livesteam
Re: Air Compressor
« Reply #11 on: December 12, 2010, 12:35:02 pm »
Thanks for your inputs.
I found a quite easy solution now for running in my TVR1A. I use a cheep DIY-compressor with 24l tank ans made a connection with silicone tube.
Page created in 0.889 seconds with 21 queries.
