This is a plastic model - I can't believe he is putting MMB900's in it More like 385's or less, so the pencells should be OK
Not only a plastic model, a SMALL plastic model. One 385 would probably sink it.
For batteries, a stick of 4 AAA rechargeable, for control a pair of Action's micro ESCs and matching mixer will do the job and power a pair of matching mini motors from the same supplier or servo motors if connecting to a very short stubby shaft is not a problem. Should be good for an hour or so. I suggested the mini ESCs because finding a home for the all-in-one unit might be a problem in a SMALL model.
The pessimistic run time could be due to the assumption that a 25A ESC will use 25A. This is not so, just because it can does not mean it will, the current depends partly on the motor, and upon the load imposed on the motor by the prop. After that, its down to Ohm's law and battery voltage. While an ESC that can handle a lot will control a little equally well, the big 'un will probably need more current to drive the output stages, so matching is a good idea.
