Thanks for the tip George. As to finding a leak under a vacuum, that is surprisingly easy...you can see it on the gauge, and you can hear it, provided it is not a tiny fracture, but you will still see it in a loss of vacuum on the gauge. To find the small leaks, simply charge with a small amount of nitrogen, 20 or 30 psi and set to with some dish washing soap, the leak will soon reveal itself, or, as you suggest, immerse in water.
I think everybody here is so used to the standard silver solder process, and is very aware of its possible shortfalls, especially when incorrectly done. Introducing a different concept does bring out concerns, both legitimate and not so. Brazing with oxy/acty is a much tougher proposition from the point of view of its inherent strength when correctly fabricated. Yes I concede that I have much to learn. But unless there is something I am unaware of regarding chemical interactions within the processes of a boiler, I suspect that my approach, especially regarding the fire tubes, will be successful. There again, this is a project in motion, and so subject to revision and outright rejection when errors occur or are revealed by superior experience. So please don't think I am brushing your concerns aside, which my holding to my course would seem to imply. Please keep the comments coming, and hopefully we can all learn something.
